11-26-2010, 11:48 AM
#21
Trailer: 16 ft U-Haul VT
Thank you for the compliment. Since that picture, we added a spare tire holder and painted the frame royal blue to match the other blue.
Cindy
11-26-2010, 08:04 PM
#22
Originally Posted by Andy B
The smallest window units typically available are 5000 btu and are made to cool a room several times larger than the interior of a fiberglass trailer. I don't know a lot about roof units, but I think that the smallest roof units are considerably larger in cooling capacity than the small window units because most campers are much bigger than fiberglass eggs.
If you read anything about sizing AC units to an application, they always warn not to get to much cooling capacity because the AC will cycle to fast and not do a good job of removing the moisture from the air.
A lot of that concern depends on what kind of heat conditions you encounter. My 5000 Btu unit does well in the 80-95 degree range, but we have repeatedly found ourselves camping in Palm Springs, CA in July when the outside temperatures easily reach 115 degrees with 7% humidity (and there is no shade). This is when I wish I had a 13,000 Btu roof unit AND a swamp cooler...
11-27-2010, 05:45 AM
#23
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Fred,
115 degrees seems pretty warm, but the 7% humidity seems pretty nice.
Can't imagine what the "Feels Like" conditions are. You might have to graduate to a 6K AC unit!
Most every summer we have periods when the temp is in the mid to high 90s with humidity at/or above 50%, and little to any breeze at all. Stepping outside will induce instant sweating, and hard to breath.
Other than cutting grass with a riding mower (making our own breeze), any work to be done outside requires us old folks to start at daylight and work toward the shade, when the sun appears, and give it up around 10:00 AM or so. Can't imagine how the prople doing roofing, resurfacing roads, taking down trees, and so forth, deal with it. God bless them!
Kip
11-27-2010, 05:51 AM
#24
Cindy
Cindy,
The inside walls appear to be fiberglass. Are those U-Haul EGGS double walled with insulation between them?
Somebody in your group sure has a good eye for colors, inside and out!
Kip
11-27-2010, 06:09 AM
#25
Yes, the UHauls are double-hulled. We really like the fiberglass inside walls. We can just wipe them down when dirty.
As for insulation, I do not really know. I do know that we camp in South Dakota in March, we are plenty warm with what we have to heat it. Our air conditioner is both a cooling one and a heating one. Then we use one of those little electric heaters you can pick up at a a Walmart.
CindyL
11-27-2010, 07:23 AM
#26
Trailer: 1983 Scamp 13 ft Standard
From a different perspective, consider tow handling and how a heavy appliance would effect things. A location lowest & closest to the axle has the least effect on handling.
ConwayBob
11-27-2010, 07:40 PM
#27
Trailer: U-Haul VT16
Kip,
One other thing to consider is cooling capacity. These fiberglass trailers are very small. The smallest window units typically available are 5000 btu and are made to cool a room several times larger than the interior of a fiberglass trailer. I don't know a lot about roof units, but I think that the smallest roof units are considerably larger in cooling capacity than the small window units because most campers are much bigger than fiberglass eggs.
Another consideration is if it will ever be run using a generator, the roof units may require a bigger generator.
Andy
couldn't you crack a window if your AC is too powerful?
Kip, no insulation in the U-hauls unless you add it yourself. There us some access in some spots through bins and cabinets.
Planning our next Escape!
11-27-2010, 09:44 PM
#28
Trailer: 1980 Burro
Yes, you could open a window with a larger than needed AC to reduce the temperature. Depending on the climate that would work to control temperature but maybe not humidity. It seems that using the right size AC is a better solution. A 5000 btu window unit may be a little larger than needed for efficient moisture reduction but a 9000 or 13000 btu roof mount would be much further from optimal.
I am not an expert, so feel free to correct me if I say something incorrectly. When the temperature of the air is lowered with all other things being equal, the % humidity increases. If I am interpreting the charts that I Googled correctly, using the example of 115 F at 7% humidity, if the air temperature is lowered to 70 F without removing any water, the humidity increases to 28%. That is still low humidity.
If the temperature outside is 95 F and 55% humidity, the humidity will reach 100% when the temperature is lowered to 76F. This shows that having an AC unit that cycles long enough to effectively remove water is important in a humid climate but may not be as important in a dry climate.
A larger AC unit still costs more to buy and to run, weighs more and would require a larger generator to run without a hookup. It is the rooftop air conditioner power requirement that causes some people to get a 3000w vs a 2000w generator resulting in even more weight and expense.
Andy
11-27-2010, 11:12 PM
#29
That's the crux of the matter; at 115 F a 5000 Btu "Air Conditioner" is incapable of lowering temperature; it ceases to have any effect. It just blows HOT until the outside temperature drops below 95. Then it will start to cool again.
11-28-2010, 07:23 AM
#30
Andy
Hi Andy,
Not argueing with what you read or what you wrote, because that is one of those phenomenon that goes way over my head. No doubt the folks that wrote your read have done controlled experiments and their data is correct.
I'm thinking of humidity being the amount of moisture suspended in the air. Layman logic dictates that in an enclosed environment , the humidity level would remain the same until the temperture was lowered enough that the water vapor began to liquify. At that time the moisture is still present, but not necessarily suspended in the air. So humidity would drop in the cooler environment. On the flip side, when the liquid "water" is heated and turns to vapor, the humidity increases.
During a summer rain, the air cools. After the rain, the sun heats things and the liquid on the ground turns into a vapor and humity seems to rise.
However, my thinking is subject to be wrong, Big Time!
Agree that the correct size AC would likely be more benneficial in removing excess moisture. Generators or Generator/inverters in the 2K watt range can be lifted and handled fairly easily and can run a 5K-6K BTU AC with little noise and little fuel.
Honda and Yamaha both make excellent ones. Roof top units generally require a larger, thristier Generator.
I don't understand this from Fred. But, I would bet he is right! : That's the crux of the matter; at 115 F a 5000 Btu "Air Conditioner" is incapable of lowering temperature; it ceases to have any effect. It just blows HOT until the outside temperature drops below 95. Then it will start to cool again.
Thanks,
Kip
11-28-2010, 07:40 AM
#31
Thanks Matt!
Apparently they depend on the relatively dead air space between the walls for insulation. Seems to work well, judging from Cindy's comments!
Kip
11-28-2010, 08:14 AM
#32
Trailer: 1980 Burro
A 5000 BTU AC is certainly capable of lowering temperature at 115 F. It may not lower the temperature as much as you would like. The heat coming in through the walls may be larger than the 5000 btu capacity in a uninsulated trailer so the overall temperature in the trailer may not go down, but the air temperature coming out of the AC has to be lower than the air temperature going into the AC unless the air conditioner is not working.
115F with very dry air is an extreme condition. A condition that most of North America does not experience. A far more common condition is heat in the 80's or 90's with plenty of humidity. One size AC does not fit all conditions. For most of the country 5000 btu is a better size than 13000 btu for a small trailer because it provides plenty of cooling and is better at controlling humidity.
11-28-2010, 08:26 AM
#33
Trailer: 1980 Burro
The % humidity in the air refers to how much moisture as a percentage of the maximum amount that the air can suspend. The warmer the air is the more water it is capable of suspending. When the air temperature goes down without removing any water, the capability of the air to hold water goes down. Because the full saturation value is lower, the same amount of water in the air is a bigger percentage of the new maximum.
11-28-2010, 10:40 AM
#34
Kip,
Just curious - are you looking at that Uhaul on ebay? If so, and you buy it, there are lots of posts on here, compliments of Bridgette and others, that outline repairs to the windows. That one looks like it has or has had leaks (Ours leaks again too #@*!).
CTs (the smaller Uhauls) do not have the strength to hold an air conditioner on the top although some people have put them there and others have added braces and then put them on top. The VTs were made for one on top.
(Just mentioning this after reading your signature line and the questions on the ebay ad.)
CindyL
11-28-2010, 07:29 PM
#35
Trailer: U-Haul 1985
With regards to the value of the air between the double hulls (as far as insulation value) it does not add as much as you'd think. Using a small heater, there is no problem with keeping the UHaul warm, but the lack of any insulation between the warm inside and the colder outside air means that the temperature drops much quicker than a trailer with ratfur (which is lightly insulated). I camp with a friend that has a Scamp and her trailer will maintain a comfortable temp much longer than my UH. But I love the smooth walls much, much more than the fuzzy. Wish there was an easy way to install foam between the hulls - it would make the trailer pretty much PERFECT in my opinion!
11-28-2010, 08:43 PM
#36
Trailer: 93 Burro 17 ft
Originally Posted by Marty D
I have a UHaul 13CT and there isn't a lot of space to spare. The PO took out the original furnace and left a vacant hole for me to look at. I put a portable room heat pump (heat and air capabilities) in that spot. The exhaust/air input on the heat pump conects to the original exhaust port of the camper. The unit is out of sight, out of mind when not in use. The only real down side is that I must leave open the closet door to enjoy air or heat. I may put in a front vent so that i won't even have to do that. It can easily be taken out and used in the house if need be.
You mention your portable heat pump. Would that be one of those "Cool Cat" brand units? Or something else? I've been wondering if a Cool Cat (or your unit, if different) would be appreciably quieter when operating. It's hard for me to sleep with a noisy AC unit running that close to me, but I also can't sleep if I'm too hot!
11-29-2010, 05:40 AM
#37
Kip,
CindyL
Cindy,
Not aware of the Ebay U-Haul ad until now.
Gotta go look!
Thanks'
Kip
11-29-2010, 06:05 AM
#38
Pam,
From the info gathered here, and some pictures that were posted, it appears that the Scamps have "Reflextic" glued on the inside walls and "Ratfur" glued to that. Checked out Reflextic at Home Depot and found it to be basically thin (1/4") bubble wrap with a layer of reflective foil on both sides. Apparently it works well.
Do the U-haul walls collect moisture when it is cold outside and warm inside?
Kip
11-30-2010, 03:36 AM
#40
Andy,
Just to confuse myself even further, here are a couple of interesting
links. Looks like you were correct and I wasn't!
Kip
What is dewpoint temperature?
Temperature, Dewpoint, and Relative Humidity Calculator
