Attaching an Outsunny Awning w/ 3m VHB tape? - Fiberglass RV
Old 03-18-2018, 05:42 PM   #1
Trailer: Hunter Compact II
Hi Everyone,
I was thinking about attaching this Outsunny car awning to the side of my Hunter Compact II with 3m vhb tape.
https://www.amazon.com/Outsunny-Car-.../dp/B071Y1921B
It weighs around 20 lbs. Do you think it would work or probably be too heavy? I'm going to attach a solar panel with the same tape so thought it might be worth a try. Let me know if you have any thoughts!
Would love to be able to attach the ARB car awning that way but i'd imagine it would be too heavy/bulky at 35lbs: https://www.amazon.com/ARB-4x4-Acces...b+awning&psc=1
I just want to avoid drilling into the fiberglass.
Planetcookie is offline   Reply With Quote
Old 03-19-2018, 09:27 AM   #2
Trailer: Outfitter truck campper
No way that tape will hold an awning. You might use it though between the awning and trailer where you mount the fasteners in order to seal the fastener and mitigate any rattles. I'm not aware that there is any way to attach an awning without drilling for fasteners unless you already have a roof rack or some other already mounted fixture that you could attach it to.
As for the solar...I used these mounts https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 with the VHB tape stuck to the camper, and then just screwed through the mount to the solar panel to hold the panel to the mount. The mounts will have to stick to a flat surface on your camper though so that might be the challenge. Good luck!
TomandCallie is offline   Reply With Quote
Old 03-19-2018, 09:52 AM   #3
Trailer: Casita 17'
I saw it at the GE&H rally this past weekend, gentleman said it worked well. It was a bag awning and the rail was attached with the tape.
Richard
dblcola is offline   Reply With Quote
Old 03-19-2018, 10:08 AM   #4
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Richard
I also believe that it will hold up if it is a bag type awning and you remove the awning from the rail for travel. I have been using 3M tape to hold both semi- flexible solar panels and a Renogy 160 watt panel using Renogy mounts for fiberglass application. I have had ZERO problems in 3 years sitting in the Arizona sun with this tape. I did use Scotch Bright to lightly rough up the mounting surface, and the prep that 3M has available (got it off Amazon when ordering the tape).
Dave & Paula
Old 03-19-2018, 10:54 AM   #5
Originally Posted by David B. View Post
... I did use Scotch Bright to lightly rough up the mounting surface, and the prep that 3M has available (got it off Amazon when ordering the tape).
Surface prep varies by surface material AND the type of VHB tape used (there are many variations of VHB tape).. from the 3M site:
Exceptions to these abrading guidelines are 3M™ VHB™ Tapes 4932 and 4952, as they typically perform best on smooth glossy surfaces and abrasion may reduce the bond strength.
Originally Posted by Planetcookie View Post
Hi Everyone,
I was thinking about attaching this Outsunny car awning to the side of my Hunter Compact II with 3m vhb tape....
I suggest you go to the 3M website and do some research, in particular the VHB Tape Design Guide. Then maybe contact 3M and ask which version of VHB tape you should use, what prep is needed, etc.
Old 03-19-2018, 02:52 PM   #6
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
For a solar panel "100 Watts" I used the following method that you can see on the video and I have 2 complete seasons without problem.
I check regularly and everything is o.k ..
I read someone in the group who replaced one of his solar panels after 5 years, he used the method explained in the video and he wrote that everything was beautiful under the bindings, they were still very solid. ..
Gilles
Bigfoot 15B17G.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 03-20-2018, 09:39 AM   #7
If you really have to use adhesive tape make sure you remove all wax or wax like coating from the gel-coat before sticking your parts to it.
Like said above I would not drive with the bag hanging on there.
I have a bag awning on my Scamp the rail is bolted and pop riveted to the scamp with butyl tape between the rail and fiberglass for a seal. I do not leave my awning hanging on there when I travel. One to keep it clean and less stressed. and since my trailer is out and exposed 24-7 it will last a whole lot longer if kept out of the elements when not in use.
Old 03-20-2018, 04:56 PM   #8
bsedwebt's Avatar
Trailer: Casita "Cozy-Casa"
Central Virginia
I use 3M RP45 tape as the ONLY attaching point for my 10' x 12' rope and pole awning via the 1.5" wide vinyl awning rail and it is plenty strong. I have tried other 3M adhesive tapes but all have failed except this one. Surface prep is key. Light sanding with 800 grit on both surfaces, cleaning completely and using the 3M adhesion promotion works well. This has been on the trailer for over a year in all kinds of wind, rain, heat, etc... as we camp 75 days a year. http://www.fiberglassrv.com/forums/m...ture10129.html
"Cozy-Casa" -- Visualize whirled peas
bsedwebt is offline   Reply With Quote
Old 03-20-2018, 05:09 PM   #9
bsedwebt's Avatar
Central Virginia
[IMG]
Old 03-20-2018, 05:58 PM   #10
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
Maybe I over-killed it but I attached my 8 foot bag awning with rivets every 6 inches and on the ends I placed a 1/4 bold with acorn nut on the inside of my Boler 13. I know that sucker isn't going anywhere.
Old 03-20-2018, 06:37 PM   #11
Hi Everyone,
If you have painted the trailer then the VHB tape will not be a good way to hold the awning on as the paint could separate from the surface of the fiberglass.
Old 03-23-2018, 04:16 PM   #12
Thanks for all the in depth responses everyone. I really love this forum for the wealth of knowledge. I'm going to clean the area, rough it up with scotch bright and try the 3M RP45 (and take the awning off of the Outsunny rail system). I called 3m but they weren't super helpful with VHB tape and recommended a few different liquid adhesives instead. I'll let you know how it goes!
Bradley
Old 03-23-2018, 04:20 PM   #13
... I called 3m but they weren't super helpful with VHB tape and recommended a few different liquid adhesives instead. ..
That is very interesting.. if they recommended something other than the VHB tape that they otherwise seem to think is the best thing since sliced bread, then that might in fact be VERY helpful advice. Something to consider.
Old 03-23-2018, 06:52 PM   #14
They weren't VERY helpful with "VHB tape" and recommended something more permanent by using a liquid adhesive (which they were VERY helpful with). I want to avoid the liquid adhesives that they mentioned since the solar panel or awning would probably never be able to be removed. Though I've done a lot of research online and along with this thread that certain VHB tapes are working very well with other users. Some users have called 3M and did get helpful advice on using VHB tape for such applications.
awning
Installation of New Awning Rail with 3M VHB Tape? kellyben Modifications, Alterations and Updates 20 04-07-2015 05:40 PM
Wanted: VHB Tape wanted D Davis Parts: Buy | Sell | Trade 5 01-15-2013 02:10 PM
Where to find VHB tape in Edmonton Rodger Problem Solving | Owners Helping Owners 4 09-07-2011 12:11 PM
FS: Roll of Very High Bond (VHB) tape by 3M Linda Johnson Classified Archives 1 09-28-2009 05:13 AM
Other uses for VHB tape Lisa H. Problem Solving | Owners Helping Owners 2 08-18-2009 08:47 PM
