Axle Replacement Mechanics in NC - Page 2 - Fiberglass RV
Old 10-23-2010, 09:34 PM   #15
Roy in TO's Avatar
Andrew: Great diagram! Can you create some that would demonstrate the relationship of the torsion arm to the other 4 parts of the suspension. i.e. axle tube, rubber, axle, torsion arm and spindle?
Terri:
2 thoughts.
Do some "reverse engineering" on your trailer. Check the specs for your year for the total height and headroom. That should give you some idea of how far the "kitchen floor" is off the ground. Compare your trailer to that. That should give you some idea of where you should sit.
Check the Dexter site and see if there is a distrubutor or manufacturer in your area. If not call the their customer service line to locate someone that knows their products.
Old 10-23-2010, 09:38 PM   #16
Roy in TO's Avatar
Just an offside question,
Does anybody know what all the components of a torsion axle are called?
It would be nice for us all to use the right terminology.
Old 10-23-2010, 09:42 PM   #17
IllAnnoy
Look here....
http://dexteraxle.com/i/u/1080235/f/...nformation.pdf
Old 10-24-2010, 02:41 PM   #18
Roy in TO's Avatar
Thanks Floyd, but not all the components are labelled.
Old 10-25-2010, 12:04 PM   #19
Trailer: 1982 Scamp
Originally Posted by Andrew Gibbens View Post
Yes - see diagram
Wow! What a great diagram. It makes a lot more sense to me now that I look at the picture! thanks so much!
Terri R. is offline   Reply With Quote
Old 10-25-2010, 12:06 PM   #20
Trailer: 1982 Scamp
Terri:
2 thoughts.
Great Idea! I hadn't thought of checking the original specs for height, etc. Thanks!
Uhaul Axle Replacement caleb Care and Feeding of Molded Fiberglass Trailers 1 05-21-2009 06:17 AM
Bigfoot 17 Axle Replacement Jay Moeller Problem Solving | Owners Helping Owners 4 05-19-2008 12:47 AM
Axle replacement Brad Judd Care and Feeding of Molded Fiberglass Trailers 13 01-16-2008 03:23 PM
Axle Replacement LauraW Towing, Hitching, Axles and Running Gear 5 02-15-2007 05:48 PM
axle replacement Don Meyer Modifications, Alterations and Updates 13 06-09-2006 10:07 AM
