bad day, my trailer got an "owie" - Fiberglass RV
Old 09-08-2014, 02:46 PM   #1
Mike Magee's Avatar
Trailer: Li'l Hauley
My Lil Hauley (Snoozy shell) contacted my old SUV while I was backing into the driveway. The SUV suffered a small hole in the side of the taillight.
This was a 2 or 3 mph impact. I thought, surely the Hauley will just have some rub marks at most.
Wrong!
This trailer is a lot more fragile than I thought. the outer skin and sandwiched cured resin both crumbled into tiny pieces. I thought fiberglass contained glass fibers? I don't see them.
Now I have to come up with a DIY fix of some sort. Not sure what to do. Thinking about Bondo.
How to prepare Tofu
Step 2: grill some meat
Old 09-08-2014, 03:01 PM   #2
Mike Magee's Avatar
My wife found one chunk of decent size, and I took some pictures.
This is what the outer gelcoat and the inside of the Hauley shell look like.
How to prepare Tofu
Old 09-08-2014, 03:09 PM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Don't use Bondo as a patch, get a fiberglass repair kit and sand or grind out the edges, then lay in some fiberglass mat or cloth in multiple layers to build up the area. Wait for it to totally cure then sand to shape. Then use the bondo to fix any imperfections.
is a good example how to repair
Bondo has no strength and should only be used to smooth out for a good finish.
Old 09-08-2014, 03:20 PM   #4
Dudley's Avatar
These trailers are closer to boats than they are to regular trailers and the info on boat repairs shows how close cousins they are!
From you second pictures I think it may have had a patch job done in the past or a bad glass layup in the mold where they did not imbed the fiberglass mat into the resin properly.
Old 09-08-2014, 03:20 PM   #5
Look into a product called Duraglass. It is perfect for this type of repair. If it was structural issue then I would chase a traditional full resin and glass fiber repair which would make it a repair about 2 foot around. But this small job don't make it worse than it already is.
U.S. Chemical & Plastics
DURAGLASS*NEW WIDER MOUTH
Old 09-08-2014, 04:39 PM   #6
Trailer: 77 Scamp 13
Might want to read through this thread which covers all sorts of FG repairs. You Can Repair Fiberglass
I'm with David on Bondo is really just good to fill minor surface imperfections, not so great for actual patch.
I am really not, repeat not an expert on FG but had someone suggest using silica powder available from West Marine (and probably other places) to thicken the FG resin so it was easier to work with on a vertical surface.
Wonder if resin and chopped strand mix would work as well as mat for a spot repair? I hate working with mat or cloth, every time I touch that stuff I am reminded why I would rather work with wood or metal. I muddle through using the mat/cloth but only thanks to a rich vocabulary of impolite words.
Old 09-08-2014, 04:41 PM   #7
Raz
Raz's Avatar
Vermont
Have you called the folks at Snoozy? As I recall the Snoozy construction is different than the other manufacturers. Raz
Raz is online now   Reply With Quote
Old 09-08-2014, 04:53 PM   #8
Mike Magee's Avatar
I would fill the hole with dirt and tape over it with duct tape before I will ever call the people at Snoozy for anything.
How to prepare Tofu
Old 09-08-2014, 04:55 PM   #9
David Tilston's Avatar
I sense some history there.
Old 09-08-2014, 05:45 PM   #10
Mike Magee's Avatar
I have seen that thread before (in fact I reviewed it just a few months ago), and it looks like a whole lot of work. Layer after layer, with long hours of curing in between. I want to just fill the hole with something and have it cure up and be done. For one thing, I use this trailer 5 days a week for work so I only have a weekend at most to get it fixed up.
If that Duraglas will do the job at one swipe, I'm interested. I found instructions on the tech data sheet for the product, and I just wish they defined what they consider a 'small' hole versus a 'large' hole so I'd know if this hole will be ok without any mat. Here's what it says:
For broken fiberglass: Cut out all damaged fiberglass and “V” groove the sides to be repaired.
For large holes: Cut enough fiberglass cloth or screen to cover hole and extend well back into the side.
For small holes, cracks and dents: Fiberglass backing is not needed.
http://www.uschem.com/products/docs/TDS_Duraglas1.pdf
This hole is about 1.5" across and perhaps 1/8" deep, but there are a couple of cracks, each nearly 2" long, on either side of the hole.
How to prepare Tofu
Old 09-08-2014, 06:01 PM   #11
Melanie B in NC's Avatar
Trailer: Lil Snoozy "Marigold"
Alabama
Mike - If you consulted with Snoozy folks, you would be dealing with Richard Mickle now, not Alan. Richard is very approachable and helpful.
Melanie B in NC is offline   Reply With Quote
Old 09-08-2014, 07:32 PM   #12
Mike Magee's Avatar
Alan is out of there? I didn't know that. For some reason I thought he and Richard were both in the place and working together. That would make a difference in my perspective.
How to prepare Tofu
Old 09-08-2014, 07:34 PM   #13
Alabama
Alan is not completely out the picture, but it is my understanding that Richard is running things now and making policy. You could deal only with him if you choose.
Old 09-10-2014, 11:15 AM   #14
Mike Magee's Avatar
I am giving them a try... I wrote to Mr. Mickle and will see what he says.
I asked if he thought Duraglas or Dyna-Glass, or something else, would work. While I was at it I inquired about pigment to mix in, to match the color.
How to prepare Tofu
bad hair day!! ( long ) Christi V. General Chat 3 01-15-2009 10:17 AM
Yet Another Way To Have a Bad Day Towing Steve L. General Chat 18 01-22-2008 08:40 PM
Bad Day at Escape Trailer Ind Reace General Chat 12 10-20-2007 08:48 AM
Mom's Bad Day Benita Jokes, Stories & Tall Tales 1 07-29-2006 09:58 AM
Bad bad news Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
