Batteries in the winter - Fiberglass RV
Old 11-23-2014, 06:39 AM   #1
Trailer: Parkliner
I am just wondering if it is better to leave the batteries attached to the trailer in the winter and charge every week or two or to unattach the batteries and store in my garage which stays above freezing all winter. I know most of you have been through this already, so all advice is appreciated.
Pat in Michigan is offline   Reply With Quote
Old 11-23-2014, 07:59 AM   #2
John Linck's Avatar
Madison, Wisconsin
I believe moving batteries is risky for several reasons. Repeatedly loosening and tightening high amp connections can lead to conduction (resistance, heat, fire) problems. Lifting heavy batteries can lead to back injury or cracked batteries. Also moving containers of high power acid is dangerous. Not to mention the risk of high amp discharge when your metal wrench accidentally meets the opposite conductor/pole. All of the above are real and do happen.
The best method to maintain and preserve a battery to leave it in one place and invest in a $20.00 battery minder and check the water level every couple of months.
Just saying, john
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 11-23-2014, 11:17 AM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Just saying, john
One viewpoint, and I respect it. But I would contend that coupling a trailer and driving down the road is inherently more dangerous than moving a battery. Or removing and replacing a propane tank. Or many other things we do in relation to our RVs.
Old 11-23-2014, 11:29 AM   #4
Answer as to what works best for you may come down to how long you plan on leaving the trailer parked and whether or not you are ok with paying for the power to leave it plugged in or with a battery tender on it. Also how cold it may or may not get where you live.
In recent years I have taken winter trips so the battery stays on the trailer so that it is ready to roll at any time. In years past when I know I was not going to use the trailer for several months then I removed the battery.
Old 11-23-2014, 11:40 AM   #5
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
My batteries remain with the trailer, and are kept charged by my solar panel. Even though I have a cover on the trailer, as long as I scrape the snow off the top every once in a while, the panel gets enough light to be the equivalent of a battery minder. I have a TriMetric 2025 battery monitor to keep track of the battery status. I do check the water levels every month...
Old 11-23-2014, 11:49 AM   #6
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I remove my batteries and put them on my shop bench hooked together and to a trickle charger that keeps them topped off. I also have made my battery cover much easier to get on and off than what the factory provided, and I have remote posts to someday hook solar to. For now though, given winter temps here, I like having them in my nice toasty house. I do the same thing with my boat battery, ATV battery and lawn tractor battery. Been doing it for years, but YMMV.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 11-23-2014, 11:51 AM   #7
trumpetguy's Avatar
Trailer: Airstream International CCD 28
Jon. That is interesting. The panels get enough sunlight through the cover to still produce enough volts to keep the batteries topped off. I will be installing two hundred watts on the new Oliver and was wondering if I could still use a cover. Is your cover made of Tyvek? I have 450 AH in the Trojan T105 batteries.
2007 Airstream International CCD 28
2016 Dodge Ram Sport 5.7 Hemi 4WD
trumpetguy is offline   Reply With Quote
Old 11-23-2014, 03:39 PM   #8
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Agree with Jon in that I also have seen my 50 watt panel keep my Trojan bank charged even when covered according to my monitoring system. Use a cover off eBay.
Also when you hook the 6 volt Trojans in series you don't get double the amps, unless you have four in your bank you are in the 200 + range
mmeyer is offline   Reply With Quote
Old 11-23-2014, 04:07 PM   #9
Trailer: Parkliner
Well it looks like there are lots of ways to take good care of my batteries. Carol, I live in Michigan so it gets plenty cold here. I haven't planned on going away this winter but I haven't completely ruled it out either. Can you just leave them plugged in all winter?
Old 11-23-2014, 04:56 PM   #10
trumpetguy's Avatar
yep. i do have t105s
Old 11-23-2014, 04:57 PM   #11
trumpetguy's Avatar
meant to say four t105s
Old 11-23-2014, 05:02 PM   #12
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
That's quite a load, need careful placement so you don't unbalance one side or front to back.
Old 11-23-2014, 05:02 PM   #13
I normally have my trailer plugged in all winter with a heater on.
The battery will stay charged as well.
If you can leave your trailer plugged in that's all you need the battery will maintain its charge.
Old 11-23-2014, 05:21 PM   #14
If you have a three stage "Smart Charger" you can leave it plugged in 24/7. If not you might want to leave it off and get a trickle charger to keep them warm.
parkliner
Best for batteries in winter? Bruce Wray Problem Solving | Owners Helping Owners 17 11-03-2009 05:30 PM
Optima Batteries George Cathcart Problem Solving | Owners Helping Owners 3 07-19-2009 11:21 PM
Converters Batteries Chargers Ami P Problem Solving | Owners Helping Owners 2 05-09-2009 04:34 PM
Lithium Ion batteries Daniel V. General Chat 3 03-13-2009 06:10 AM
Extra Batteries Francine P Problem Solving | Owners Helping Owners 17 03-03-2009 08:01 AM
