Battery bypass switch - Page 2 - Fiberglass RV
Old 06-02-2012, 09:36 PM   #15
I wired mine so that the battery switch removes the battery from EVERYTHING so that I can (finally - maybe - perhaps - I hope!) stop running my battery to a zero charge state every time I come home and unhook. As it was the batt was still running the "profane" detector, the circuit boards in the fridge and various & sundry other stuff. A week or two and sure 'nuff - batt is dead again. I used the same race car battery disconnect switch that is featured in other posts in this thread (I had one laying around anyway).
Now its just part of my "pretrip" to turn the battery back on, and hit the monitor panel switch to see if I need to plug the converter in to recharge the batt before leaving
By the way - just in case I come down with the occasional bout of "OOOPs", the trailer breakaway switch is NOT disconnected by that switch!
Old 06-03-2012, 06:53 AM   #16
cpaharley2008's Avatar
This a problem with used trailers that have been modified by prior owners. The intent of the the battery "disconnect" switch is just that, to disconnect the battery from the trailer. It is intended for periods on being out of use, so any detectors would not be relevant. While occupied, all detectors and the battery should be in use. Prior owners will change all this so each used trailer will have it's own peculiar set up.
Old 06-03-2012, 08:24 AM   #17
Roy in TO's Avatar
Why not just get Reace to send you a new one. Escape is still in business.
Oh to have the original manufacturer still in business and all the parts recent.
Old 06-03-2012, 09:30 AM   #18
Originally Posted by Darwin Maring View Post
It should still work if you are using shore power and your converter supplies 12VDC.
I'm assuming that the battery is disconnected from the 12 volt system for storage. There's no need to disconnect the battery when connected to shore power.
Jane.
The propane detector is powered by the 12 Volt system. Both disconnecting shore power and battery will disable the propane detector. I suppose there might be some propane detectors that are powered by disposable batteries. If that's the case they should be replaced at least once a year.
Old 06-03-2012, 09:34 AM   #19
I turned off my converter. When at home the battery is connected to one of maintaining battery chargers. (Battery Minder, Battery tender, etc.)
The only thing running when I'm not using it is the propane detector.
battery
How Does a Battery Cut-Out Switch Work? Tamid Problem Solving | Owners Helping Owners 3 07-28-2010 09:31 AM
battery switch Ron Davis Problem Solving | Owners Helping Owners 3 06-26-2007 08:50 PM
Where do I find the water bypass switch? Karalyn Plumbing | Systems and Fixtures 9 10-19-2006 01:30 PM
Battery Disconnect Switch Victor Benz Electrical | Charging, Systems, Solar and Generators 18 07-06-2006 04:33 AM
battery switch Ron Davis General Chat 0 12-31-1969 07:00 PM
