Battery charging - Fiberglass RV
Old 01-18-2013, 03:27 PM   #1
Trailer: 13' 2008 Scamp...YAY!
Battery charging
I have my trailer at a storage facility and did NOT remove the battery for the winter. I go out every couple of months, hook up, and read or do something with the trailer until the battery is charged back up, and the lights are bright again.
Someone recently told me that I could overcharge and ruin the battery by doing this. That doesn't seem likely to me, but I've been wrong once or twice. Who is wrong, me or them?
Mon
monB is offline   Reply With Quote
Old 01-18-2013, 03:55 PM   #2
Trailer: Bigfoot 2500 truck camper
Seems to me you are going out to plug in your trailer every once in a while, not leaving it plugged in for months at a time? This is the correct thing to do. Leaving it plugged in all the time is what could damage your battery. This is because most simple converter battery chargers in most trailers are not designed to taper the charge off as the battery is filled. The battery could have its electrolyte boiled away. You can purchase intelligent or smart battery chargers that can be hooked up indefinitely and keep your battery fully charged without damage.
Rene is offline   Reply With Quote
Old 01-18-2013, 07:31 PM   #3
Trailer: Fiber Stream
What do you mean by "Hook up"?
  1. Plug the trailer's 7pin connector into your tow vehicle's 7-pin receptacle and run the engine until the battery is charged by the alternator?
  2. Plug the 30 amp 110 volt shore power cable into the storage facility's power and have the trailer's converter charge the battery?
Actually, either way works, and like Rene said it is better than leaving the shore power connected 24/7 if your converter is old and does not have a 3-stage smart charger.
Old 01-18-2013, 08:02 PM   #4
Number 1....with my car running....and that's the trailer's seven pin into my van's 4 pin
The facility does not have electric available.
Mon
Old 01-19-2013, 06:34 AM   #5
Raz
Raz's Avatar
Vermont
Mon
Without knowing how you have things wired it's difficult to say how your battery is getting charged but one difference between the 4 pin and the 7 pin connection is the battery charging circuit. If you are somehow charging your battery from the light circuits (4 pin) you should really find a better way. Raz
Old 01-19-2013, 08:35 AM   #6
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
A couple of other options.
  • Use a small solar charger left on the trailer. Example:
Schumacher SP-200 2.4W Solar Battery Maintainer : Amazon.com : Automotive
  • Use jumper cables from the car to the trailer battery. It will charge it much faster. If you have a 4 pin connector on the car, I don't think you are charging the trailer battery at all.
Old 01-19-2013, 08:45 AM   #7
Well, it is what it is. As long as I have the trailer fooled, I won't complain.
I have no idea how it's wired, Uhaul put the 4 pin connector on my van. I made an appointment to install the 7 pin, they said they had no problem doing it. The day of installation when I walked in I reminded them I was there to have a 7 pin installed. It was only when the guy doing the work showed up, that they told me they NEVER install 7 pin, only 4. Since it was late afternoon and I was leaving to pick up the trailer in 5 hours, I told them to go ahead, I'd adapt. It works, for now, anyway.
Mon
Old 01-19-2013, 09:07 AM   #8
Thomas G.'s Avatar
.......... It works, for now, anyway.
Mon
OK. Just don't let the battery set while it is low in charge, especially in freezing weather.
Old 01-19-2013, 12:55 PM   #9
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
Odem,Texas
Send a message via AIM to Phil Underwood
I have never seen a 4 pin connection setup for charging a battery.
Would be very interesting to see how you are charging your trailer with your tow vehicle with a 4 pin connection .
Phil & Denise Underwood
1997 Bigfoot 21 RB
2002 F-250
Phil Underwood is offline   Reply With Quote
Old 01-19-2013, 05:17 PM   #10
Ok, what I did...
...I decided to just pull the battery and put it on a trickle charger for the cold month.
While I would SWEAR that it charged the one time I tried it hooked up to my running van, I could be wrong. I would STILL swear the lights were brighter afterwords, but it could be that I saw only what I was expecting to see. It must be a pretty good battery because it apparently has NOT been charged since I picked it up last April!
Facts all seem to point to my hook-up NOT charging the battery, so I will go with that!
Thank you ALL for your input! And I'll be looking for solar (with a controller) for NEXT winter!
Mon
Old 01-19-2013, 05:43 PM   #11
You may want to stop at Walmart or such places and buy yourself a simple plug in battery monitor - you can get them for under $20 and just plug them into the 12 volt plug in the trailer to see what the real state of your battery is.
Old 01-19-2013, 06:00 PM   #12
Thomas G.'s Avatar
Or you can buy this one for less than $3, but you need to get permission from the electronics police here, first.
2012 Mini Car LCD Battery Voltage Meter Monitor 12V Black Red Digital Screen New | eBay
Old 01-19-2013, 06:10 PM   #13
I would suggest that even the electronics police would have to agree that its way better to have one of those than just having your trailer lights as your guide to determine the state of your battery!!
Old 01-19-2013, 07:15 PM   #14
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
What's wrong with that one? I've got a couple of those in the glove box.
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
battery
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Battery Charging Dave O Problem Solving | Owners Helping Owners 5 08-05-2010 11:49 AM
Battery charging paulitzlee2 Problem Solving | Owners Helping Owners 2 07-07-2010 03:11 PM
Battery charging paulitzlee2 Problem Solving | Owners Helping Owners 1 09-15-2009 10:12 PM
Battery Charging JOE DRISSEL Electrical | Charging, Systems, Solar and Generators 23 01-08-2006 03:03 PM
