BATTERY hook-up for 16' Scamp - Fiberglass RV
Old 03-25-2006, 09:59 AM   #1
Hi there everybody,
I'm somewhat new to this forum - joined a while back, but only recently got a trailer - 1985 16' scamp.
There was no battery when I picked this trailer up. I don't see the leads in the exterior front near the propane tank, where the battery is supposed to be located. I do see a "batttery" label on the exterior where electrical cables are protruding, but they lead to the trailer light hook-up connectors. The trailer light hook-up connectors have been modified from the original. However, I checked the diagram for the original electrical system and I did not see any refrence to the battery.
My question is this: on the original trailer, was there TWO leads, one for the trailer light hook-ups and one for the battery that led from inisde the trailer? Or did the battery leads run off the same conduit that feeds the trailer lights?
I believe there should be a fuse under under the front bench. Ulimtately, according to the new wiring diagram on Scamp's website, I think I should be connecting the black and white (ground) wire to a 12V DC battery. Is this correct?
http://scamptrailers.com/wiring.cfm
thx
lenny247 is offline   Reply With Quote
Old 03-25-2006, 11:38 AM   #2
Trailer: Fiber Stream
Talking
There was no battery when I picked this trailer up. I don't see the leads in the exterior front near the propane tank, [b]where the battery is supposed to be located. I do see a "batttery" label on the exterior where electrical cables are protruding, but they lead to the trailer light hook-up connectors. The trailer light hook-up connectors have been modified from the original. However, [b]I checked the diagram for the original electrical system and I did not see any refrence to the battery.
thx
Yes, there should be a separate pair of wires (one black, one white) that is different from the bundle of wires for the tail/running light plug.
One possibility could be that your battery might be located inside the coach under a bunk???
Old 03-25-2006, 06:50 PM   #3
Pete Dumbleton's Avatar
If your Scamp came from factory without a battery installed (my 91S13 did), the battery wires and inline fuse should be in place but taped into the wiring harness near where the frame meets the trailer -- Look carefully and I'll bet you find the wiring bundle seems to be a lot thicker on that end than on the end with the truck plug. The main harness is in a sheath and the battery wires in another sheath taped to the outside.
The wires for the lights never crossconnect with the rest of the wiring -- They are powered and fused by the tow vehicle.
Almost the same for the brake wiring except they are connected to the battery thru the breakaway brake switch.
battery, scamp
Scamp/Boler Bottom Door Bar Hook Rick G Care and Feeding of Molded Fiberglass Trailers 26 12-10-2010 05:58 PM
Queston How do you hook up an auxillary battery to my 1976 Trillium Randy Howarth Care and Feeding of Molded Fiberglass Trailers 1 06-26-2010 10:01 PM
Battery hook up - Bigfoot Carol Crawley Problem Solving | Owners Helping Owners 10 07-24-2009 07:32 PM
1983 Scamp towing hook up.. jimtesla Modifications, Alterations and Updates 3 07-31-2006 07:33 AM
Battery in a 1973 13' Scamp? Legacy Posts Problem Solving | Owners Helping Owners 3 05-08-2003 02:13 PM
