Bearing buddies - Fiberglass RV
Old 05-23-2013, 11:58 AM   #1
Trailer: Snoozy
New Jersey
Bearing buddies
How often and what kind of grease should I use?
djcolson is offline   Reply With Quote
Old 05-23-2013, 12:06 PM   #2
Are you sure they're bearing buddies or are they EZ Lube by Dexter?
Bearing Buddies are made for boat trailers that get dunked all the time. I have EX Lube hubs by Dexter and I've never put grease in them. Instead I have the bearings removed and inspected, then repacked about once a year now that I'm retired and traveling some. While working and using the trailer on week-ends and two week vacations I repacked the bearings once in 4 years.
Old 05-23-2013, 12:10 PM   #3
Bearing Buddies are made for boat trailers .
Old 05-23-2013, 12:47 PM   #4
Trailer: Snoozy
New Jersey
I stand corrected, I have the spindle lube type, not bearing buddies. The grease that is visible now is white. I want to use the correct grease.
Old 05-23-2013, 01:36 PM   #5
frank_a's Avatar
Trailer: 2012 ParkLiner #006
My friendly suggestion would be to go to your local auto parts, tell them what you want grease for, and buy what they suggest. All three of my trailers (boat, utility and travel) get the bearings inspected yearly, and get cleaned and re-greased. I've been doing that more decades than I like to think. I have no use for fancy, self greasing hub caps of whatever kind. I'm just an old fashioned fellow. I get marine grease for the boat trailer and regular plain old bearing grease for the others.
Frank
Old 05-23-2013, 02:28 PM   #6
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
If I had a trailer as new as your Snoozy, I'd ask the manufacturer what type/brand is in there already and use that. There are different schools of thought as to the wisdom of (possibly) mixing types- why take a chance?
Francesca
Old 05-23-2013, 03:47 PM   #7
Here's a link to Dexter's maintenance page.
http://www.dexteraxle.com/i/u/614960...rings_3-13.pdf
Old 05-23-2013, 03:53 PM   #8
Is the Snoozy axle a Dexter, Byron?
This is one of Carl's pics of his Snoozy axle, and I've been trying without success to read the mfr. name on the label :
Old 05-23-2013, 06:16 PM   #9
I have a Dexter 3,500# with EZ-Lube spindles. I bought two tubes of Lucas Red "N" Tacky #2 based on talking to a service fella at Camping World. I could NOT find even ONE of the brands on the Dexter PDF Service Bulletin anywhere in Portland, Oregon. I pumped enough grease through the zerk to see a change in color. Drove the trailer a total of about four hours last weekend and the axle stayed very cool.
YMMV
Old 05-23-2013, 07:19 PM   #10
carlkeigley's Avatar
NE Oklahoma
I just went outside to find out the brand for you.
It says: "MADE IN THE USA by Tie Down Engineering"
Marine Aftermarket & Manufactured Housing - Atlanta, Georgia - Tie Down Engineering
Old 05-23-2013, 07:39 PM   #11
NE Oklahoma
WHEEL BEARING LUBRICATION.
Shading indicates the recomendation for the correct
amount of grease in wheel hub. (Fill wheel hub with
grease to inside diameter of outer races and also fill hub
grease cap.) Never use grease heavier than 265 A.S.T.M.
penetration (No. 2 grade). Grease bearing cone by
machine or by hand method. Force grease between
rollers, cone, and cage. It is not recommended that a
pressure grease fitting be installed on the hub.
http://www.tiedown.com/pdf/c125.pdf
DON'T KNOW IF THIS IS THE CORRECT INSTRUCTIONS.
THERE ARE HUNDREDS OF THEM ON THEIR WEBSITE.
http://www.tiedown.com/technical-support.html
Old 05-23-2013, 07:45 PM   #12
NE Oklahoma
AXLE Q & A
http://www.tiedown.com/pdf/b1063.pdf
Old 05-23-2013, 08:35 PM   #13
I guess the axle is NOT Dexter.
Nor is it E-Z Lube.
Here's Dexter's E-Z Lube description
http://l.b5z.net/i/u/6149609/f/produ...-Lube_7-11.pdf
Note that the grease travels in the center of the spindle to inner bearing then out to outer bearing. The Tie Down appears to be closer to bearing buddies where the grease goes in the front until you blow the rear seal. In other words be very careful.
In both cases they expect you to use a manual grease gun to reduce blowing the seal thus getting grease into brake drums.
Old 05-23-2013, 10:27 PM   #14
Perry J's Avatar
Trailer: 16' Casita
I have been towing for a long time and never lost a wheel bearing.
I do have bearing Buddies in my boat trailer.
The only trailer TT I've owned was a Trillium Jubilee that I bought.
The guy said he had no idea why the brakes didn't work.
I got it home and pulled a wheel off and there must have been 4 pounds of grease in the hub.
In my opinion wheel bearings are the most trouble free part of our trailers if you clean and pack them every few years.
RV Buddies Donna D. General Chat 7 10-24-2008 06:11 AM
Fishing buddies Glenn Baglo Camping, Campout Reports 7 09-15-2008 07:18 PM
Bearing Buddies, be careful! John Perry Towing, Hitching, Axles and Running Gear 12 08-14-2007 03:09 PM
Buddies james kent General Chat 0 03-09-2007 03:33 PM
Bearing buddies Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 05-23-2003 04:25 PM
