Best way to stop a leak? - Fiberglass RV
Old 09-06-2010, 07:20 PM   #1
Trailer: 1980 16 ft Scamp (Restored)
Unhappy Best way to stop a leak?
I've just replumbed my 1980 Scamp with plastic pipe. The toilet inlet fitting leaks, from the threaded plastic side (1/2"), the clamped tapered side is holding fine. I've tried several times wrapping the threads with teflon tape , it's now dripping slower. I purchased a 1 oz. tube of pipe joint compound, but the How-to websites say tape should work better on plastic. Before I use the joint compound, has anyone got a suggestion? (I got tired of cleaning up water (fortunately it's in the shower), so I installed a low-point drain so I could drain the system each time before taking the fitting loose again.)
Thanks
Lawrence W is offline   Reply With Quote
Old 09-06-2010, 07:49 PM   #2
Trailer: 2014 Escape 21
Virginia
Thanks
Teflon tape for water comes in two thicknesses. The thin tape is normally white on a blue spool. The thick tape is pink on a pink spool (Lowes). Today at Home Depot they had the thick tape (white) on a red spool. The thick tape really seals better. Also check your plastic female fitting closely they will sometimes crack.
The yellow teflon tape is for gas fittings.
Eddie
Old 09-06-2010, 08:09 PM   #3
IllAnnoy
Eddie
Teflon comes in a paste sealer as well...
Teflon Tape, Teflon Thread Sealant
Also, if you can find one, replace the fitting it may be cracked or the threads may be overcut.
Old 09-07-2010, 09:45 PM   #4
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
My inlet valve leaks also and drives me insane. What I just did (seriously, five minutes before reading this!) was to put an inline valve in the line right before the toilet. I figure I'll just leave it closed most of the time as we usually use the campground restrooms but I can turn it "on" in an emergency if I have to and the water leakage will only be for a minute or two as opposed to all the time.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 09-08-2010, 06:39 PM   #5
Matt in SV's Avatar
I keep running into situations where prior owners have used teflon tape on compression fittings. Doing that can create problems. I don't know if what you've got there is pipe or compression fitting, but it's a thought.
Regards,
Matt
Planning our next Escape!
Old 09-09-2010, 06:38 AM   #6
Trailer: currently shopping
New Hampshire
Anyone out there familiar with Love Bugs?
I think I'm about to purchase one however now I'm told that the front and rear windows (which are slider style) were bolted shut by previous owner and that the back one had a leak which the current owner plugged with silicon? I'm starting to get cold feet about this, the trailer is a 1973, and all redone inside & out but the fact that when it was refurbed that the windows were not properly replaced or resealed worries me. Also, apparently there's no dining table, removed by prior owner. Beyond this it actually is a very nice looking little trailer but I've not seen up close as it is 13 hrs from me. Help! Advice please. Thanks
Lee Ann
Lee Ann P. is offline   Reply With Quote
Stop the Bleeding! Per Walthinsen Problem Solving | Owners Helping Owners 1 04-18-2008 09:51 AM
Truck Stop Paddy Morris Jokes, Stories & Tall Tales 2 07-23-2006 07:26 AM
Stop me Gina D. General Chat 52 02-25-2006 01:24 PM
Must stop/Addicting Legacy Posts General Chat 1 05-23-2003 03:38 PM
Pull, Steer and Stop Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 01-05-2003 10:40 AM
