If yours is anything like mine, there is a spring loaded pin at the top of the screen door that fits into a plastic piece with a hole in it. With a knife or similar tool, you can press down on that spring loaded pin and it will release from the plastic piece and you can then pull the door toward you and lift it, releasing the bottom pin from the hole it is in.
