Big Foot Window repair - Fiberglass RV
Old 09-10-2016, 08:46 PM   #1
Trailer: Bigfoot 25 5th wheel
Most of the windows in our bigfoot (26ft 5th wheel) appear to be of tempered , shaped glass, with a aluminum "frame" along one end of the glass. The frame in one of the windows has come loose and needs to be re-attached.
What should I use to fasten the frame to the glass (silicone ???)
Villy
VillyM is offline   Reply With Quote
Old 09-11-2016, 08:40 AM   #2
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
Villy I would use butyl tape 3/8 X 1/16 if there is room, if not use butyl chalk. This is what we used when RVs came into our shop. We always hated to see one come in that silicone was used on.
Cheers
Doug
Doug P. is offline   Reply With Quote
Old 09-11-2016, 10:31 AM   #3
Butyl Tape
Can't find this in the RV catalog...
Any suggestions where I should look ??
Thanks
Villy
Old 09-11-2016, 11:10 AM   #4
Big Foot window question
I should have provided some more details.
The window is a slider. The moveable part is a sheet of glass with an aluminum metal h channel on the one side. Are we on the same page ???
Old 09-11-2016, 11:16 AM   #5
Doug P.'s Avatar
Southern Alberta
Hi Villy
Sorry I was on a different page, for what you are doing silicone is good.
Cheers
Doug
Old 09-11-2016, 01:00 PM   #6
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
Sounds like the channel is acting as a chip guard protector for the edge of the glass. That edge is always on the inside of the fixed pane. Just a few areas of clear caulk in the bottom of the channel will be sufficient. By a few areas I mean a small area of caulk at each end and a couple of areas towards the center. Don't over do it with continuous caulking. The channel should not be almost impossible to remove because potentially it could be put onto a new piece of glass should that pane ever get broken.
I myself might choose to get a small tube of Lexel for the job if you don't have use for a big supply of caulk. The reason for choosing Lexel is that it is handy to have in your emergency on the road repair kit. It is not silicone based, it does work with glass, fiberglass, vinyl, rubber and aluminum. It will stick to damp surfaces which is why it is just right for an emergency repair kit if you get a leaky spot in a rain storm. It is crystal clear and it dries quickly. The tube of material can even go through freezing and still be used afterwards. It does come in small squeeze tubes. Sold at local hardware stores and at big box Home Center stores most everywhere. They advertise it as the duct tape of caulks
http://www.sashco.com/products/lexel/
OH | 2008 25 Foot Big Foot For Sale $24,500 Boomer Classified Archives 12 02-07-2014 12:26 PM
OK | 2008 25 Foot Big Foot For Sale $24,500 Boomer Classified Archives 0 07-11-2013 05:39 PM
window lockstrip tool?? How to repair window parts. TaniaD Problem Solving | Owners Helping Owners 8 09-18-2012 08:28 AM
SOLD 1986 Big Foot - 18 foot on EBAY Dave Baston Classified Archives 31 01-16-2008 05:41 PM
Big Foot owners club Legacy Posts General Chat 6 06-10-2003 05:04 PM
» Virginia Campgrounds
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
