Here are some pictures from the renovations. The delaminated plywood, sticks and foam were removed from the bunk area. The inside of the
fiberglass shell was cleaned. The original horizontal crack in the lower front bunk area was filled and covered with two layers of 6 oz fibreglass cloth on the inside. Several 1x2's were glued to the side panels and aft/stair area to support the edges of the plywood. The first layer of 1/2" plywood (in three sections) was wetted out with epoxy, the fibreglass was wetted out and a thin layer of thixotropic expoxy spread. The plywood was bolted down to the frame points, screws were installed upwards from the
propane tank cover, and also from several point under the bunk; to ensure that the fibreglass was in contact with the plywood. A second layer of 1/2" plywood was expoxied down over the first. The nose forward, angled section) plywood was expoxied down using the same proceedure as above. A 1" layer of blue foam was glued (PL300) to the bunk plywood, and a final layer of panelling was glued to the top of the foam. Then everything, including the steps were re-carpeted, and the cupboards reinstalled. While the finished product looked marvelous, unfortunately, I don't have a finished picture, because as soon as it was completed, the mattress was put back in and my friends departed on a test camp. The repaired bunk area is utterly solid, looks great, and should easily last the life of the trailer.
