Boler Door Gasket/Seal question - Fiberglass RV
Old 03-21-2016, 07:09 PM   #1
Hi,
I'm a fairly new owner of a 1974 Boler, and we've just used it for the first time a few days ago.
My question: What sort of door gasket/seal is it supposed to have?
Is this material from the Scamp site correct (see scamp link)?
Tapes & Trims : Black Plastic Trim (Price Per Ft)
My Boler currently has a huge fat 1" square automotive grade gasket along the seal lip, but because of it's thickness it gives a ton of resistance to closing the door, I know it cannot be good for the hinges or more importantly the attachment points. This is a high priority for me, so any thoughts/comments would be great!
Guy with a Boler is offline   Reply With Quote
Old 03-21-2016, 09:27 PM   #2
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
The edging shown in the Scamp link is not the door seal. It is used to provide a clean edge aground the door opening between the fiberglass and the Rinoskin insulation material.
I personally use a white open cell foam, adhesive backed weather stripping. I believe the dimensions are 3/4" wide x 1/2" thick. You can get different thicknesses depending on your door gaps.
This weather stripping can be picked up at Home Depot or the like and is used for home window weather stripping.
I like the open cell foam because it crushes flat with little effort and does not make the door too difficult to close. But it does keep out road dust and bugs!
Last time I changed the weather stripping was over 5 years ago and it is still going strong (it has yellowed a little but otherwise still holding up).
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 03-22-2016, 12:22 AM   #3
Thanks very much.
1. Do you use this material instead of or in addition to the trim piece I linked?
2. I take it that it would be applied around the door opening close to the edge/lip?
3. Does anyone have a photo or a link to a photo that would be a good template to follow? I've been looking but pics seem small or not very clear...
Thanks very much,
Chris
Old 03-22-2016, 07:25 AM   #4
Trailer: 2005 Scamp 16
ID:	93606We used the same stuff as jkmboler, purchased from Home Depot. Originally I ordered the new door seal from Scamp, but it wouldn't squish down when I closed the door, so my door wouldn't latch. We used the product from Home Depot INSTEAD of the Scamp door seal and it has worked really well. You can see it is the black line around the door in this picture.
emij is offline   Reply With Quote
Old 03-22-2016, 10:06 AM   #5
jkmboler's Avatar
Manitoba
Originally Posted by Guy with a Boler View Post
Thanks very much.
Thanks very much,
Chris
1. In conjunction with the trim piece you linked.
2. Yes, follow the profile of the outer edge of the door.
3. You can see the black weather stripping in emij's photo. I put the weather stripping on the camper body, but you could also put it on the door.
1974 Boler 1300
Old 03-22-2016, 06:43 PM   #6
Trailer: Perris pacer
I bought gasket material at O'Riley auto parts store , 13 ft for $25 ! Worked out perfectly ! Has a lip and everything
mexbob5150 is offline   Reply With Quote
Old 03-23-2016, 12:39 AM   #7
thanks for the replies!
boler
Trillium 1300 Door Seal or gasket replacement Irene Problem Solving | Owners Helping Owners 1 07-17-2014 07:32 AM
Wanted: Backframe gasket and window seal Paul7 Parts: Buy | Sell | Trade 0 06-23-2012 06:25 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
wanted: window seal/gasket jalousie windows Amy W Classified Archives 5 08-21-2010 06:21 AM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
