That's about 1/2 the size of my original, which is almost square. I like the idea of balancing them front and back but my frame wouldn't accomodate that, as only the rear has the step in the frame. Is parallell and on either side, as close as possible to the axle an option to reduce bounce?
Since my trailer is still up north in storage, I asked Jean L for his measurements.
Between the frames is 45” wide x 44 “ front to back
I'm thinking of placing both tanks behind the axle parallel to the axle (as Alf describes) with the grey water closest to the rear. Hopefully I can get Polyrama to supply different fittings for the tank I intend to use for grey water. I'm more likely to tow on the highway with fresh water so keeping it closer to the axle keeps the
weight better balanced. OTOH one is more likely able to empty the grey water before hitting the highway.
As for the install, I'll have to move the freshwater fill from rear curbside to mid streetside. I'm thinking of putting a switched 12V outlet where the old fresh water fill exists.
Re: Bolerama ... We've booked site 70 on the Hill. Not intentionally being anti-social but we've got a new pup that were not sure how she'll react camping in the group area. You are welcome to drop on by, chances are I'll be puttering with something and would welcome a break. I'm pretty sure that if we were in the group area I'd be looking for a chance to get some puttering done. Maybe in a couple of years we'll be able to give the group area a try.
