Brake cleaner is the best - Fiberglass RV
Old 04-10-2015, 01:18 PM   #1
MisterBilliam's Avatar
Trailer: 1970l Airstream
New Mexico
Send a message via Skype™ to MisterBilliam
Thanks to this site. I was tipped off as to what actually DOES take decal glue off. Brake Cleaner! Cheap - easy to get -and not so bad on the nose. Thanks
MisterBilliam is offline   Reply With Quote
Old 04-10-2015, 01:45 PM   #2
It may be the best for a metal Airstream but NOT for a fiberglass trailer as you could damage the gelcoat due to the various ingredients found in brake cleaner. Its not meant to touch any plastics or paint.
Whats in Brake Cleaner
Old 04-10-2015, 01:59 PM   #3
I prefer to use WD-40 its much safer on the surface your planning to keep.
Old 04-10-2015, 02:21 PM   #4
Raz
Raz's Avatar
Vermont
A while back someone suggested WD 40 is mostly kerosene. I don't know if that's true or not? Raz
Old 04-10-2015, 02:44 PM   #5
Trailer: Bigfoot 17' DLX
Alaska
Gelcoat is neither plastic nor paint. I've never had any trouble with brake cleaner on fiberglass. As with all solvents though, a test in an inconspicuous place is always a good idea.
trainjunkie is offline   Reply With Quote
Old 04-11-2015, 11:12 AM   #6
I have used brake cleaner to remove tar on fiberglass and have not seen any negative effects (yet), but as in all things moderation is best. As a side note brake cleaner really does a nice job killing weeds that grow in the driveway cracks.
larryf is offline   Reply With Quote
Old 04-11-2015, 11:37 AM   #7
Trailer: EggCamper 2012 #109, by 2006 Tundra or 2014 Outback
Western Massachusetts
A very small amount of Acetone is also a good cleaner for fiberglass gel coat.
coastsignal is offline   Reply With Quote
Old 04-11-2015, 11:50 AM   #8
Roger C H's Avatar
What about Goo Gone?
Old 04-11-2015, 12:32 PM   #9
Ian G.'s Avatar
Won't hurt the gelcoat Carol. The solvents in Brake Clean are not as strong as lacquer thinner and I have used a ton of both brake clean and lacquer thinner on my trailer and gel coat.
The original Brake Cleaner was tetrachloroethylene (perchloroethylene) commonly known as dry cleaning solvent. The product was banned or restricted for sale to the public so the newer versions that are now available are usually a non chlorinated substitute.
As with any product test an area before using it. I have definitely seen brake clean melt plastics, pour it in a styrofoam cup and the cup vanishes but no effect on fiberglass or gel coat.
Ian G. is online now   Reply With Quote
Oven Cleaner Cleaner? Ruth C. Care and Feeding of Molded Fiberglass Trailers 16 06-02-2011 08:52 PM
My new favorite cleaner Donna D. General Chat 1 08-27-2009 09:35 AM
Anyone use "Awesome Spray Cleaner"?? Carolyn Patterson Care and Feeding of Molded Fiberglass Trailers 20 08-16-2008 10:53 PM
Fiberglass Cleaner and Polish Chester Taje Care and Feeding of Molded Fiberglass Trailers 27 08-07-2007 09:15 AM
Electrical contact cleaner Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 03-25-2003 03:09 PM
