Brakes for a 1976 Trillium 1300 - Fiberglass RV
Old 05-12-2015, 02:53 PM   #1
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
The axle on this trailer is in good shape, with the wheels sitting great in the wheel well. No sag at all.
The axles do have a square mounting pad for installing brakes. Do I just buy a left and right brake assembly? I see there is 7" and 10". I assume for a light trailer like this, I just need 7", correct? The ones I have seen online don't seem to have a drum. Do I need to buy that too, or is it part of the brake assembly.
I have no concerns with doing the job. I just would like to know what I need before getting in to it.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 05-12-2015, 04:11 PM   #2
Trailer: 76 Trillium
We also have a 76 trillium with the square plates on the axle as you do, interested in any info from those who know, we have a misca trailer outlet near us and princess auto not to far
Tipsy is offline   Reply With Quote
Old 05-12-2015, 04:21 PM   #3
Trailer: Bigfoot B-17 CB
You will need brake assembly's which consist of backing pates, shoes, magnets and hardware and you will also need hub and drum assemblies which include new bearings. Eastern Marine Trailer Parts Superstore website will give you some ideas of the parts you need. You can most likely get the parts you need locally but the Eastern website will give you a good place to start.
Old 05-12-2015, 04:24 PM   #4
You will also need wiring including a brake away switch and a brake controller.
Old 05-12-2015, 04:30 PM   #5
Thanks for your input, Jack. Thomas G just PM'd me with similar information. Realizing I needed to change the hub to a drum/hub combo was the bit of information that made the light bulb go on in me head.
I will go to Eastern Marine to have a look, but no doubt can get the stuff locally.
2017 Escape 5.0 TA
Old 05-12-2015, 04:31 PM   #6
I finally found a video on adding brakes, most of them just dealt with changing the brake assembly, which is what had me questioning the drum thing in the first place.
2017 Escape 5.0 TA
Old 05-12-2015, 05:33 PM   #7
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
One important thing I learned while putting brakes on our 13' Scamp, was when having a leading arm suspension, one needs to switch "left for right, and right for left" to have them work properly.
Dave & Paula
brakes, trillium
New Electric Brakes/hubs on '76 Trillium 1300 georgewa Problem Solving | Owners Helping Owners 45 05-18-2013 09:53 AM
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
Trillium 1300 - electric brakes Lloyd S. Towing, Hitching, Axles and Running Gear 4 07-05-2009 08:40 PM
SOLD-1976 Trillium 1300 for sale on e-bay Evan W Classified Archives 24 01-04-2009 05:29 PM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
