Broken 3/16 rivet maybe? - Fiberglass RV
Old 08-10-2015, 01:27 PM   #1
jenbooks's Avatar
Trailer: Casita Spirit Deluxe 2003
Hi all. A snap cap fell off on the upper side, and it doesn't fit back on, so I assume I'm sort of looking at a broken rivet in there?
I can get a rivet at Lowe's, Casita told me. (Although I ordered a pack from Little House as well so I will have everything on hand). Casita said the 3/16 can indeed break.
How do I get the piece out, and install a new rivet? Seeing as this is my first experience with rivet--the word formerly meant "riveting" as in absorbing, gorgeous, etc.
jenbooks is offline   Reply With Quote
Old 08-10-2015, 07:27 PM   #2
Keaner's Avatar
Trailer: 1973 13' Boler
Hi Jen, just drill off the top of the rivet. Use a bit larger than the shank of the rivet and the top will come off like a washer then you can just push the rest of the rivet through the hole.
Cheers
Keaner is offline   Reply With Quote
Old 08-10-2015, 07:50 PM   #3
there is a plastic piece that goes under the head of the rivet that the cap snaps on to. possibly that broke and not the rivet. if the rivet broke then there would be no head to drill off. if you have to replace a rivet be sure it is long enough to go through what it is intended to hold. I replaced some of my loose rivets with machine screws and nuts
Old 08-11-2015, 01:53 PM   #4
jenbooks's Avatar
I will take a pix and post
Possible Broken Rivet DKReed Problem Solving | Owners Helping Owners 12 07-29-2015 02:13 PM
To rivet or not to rivet? johnwgorman1 Care and Feeding of Molded Fiberglass Trailers 55 05-07-2015 03:48 PM
To rivet or not to rivet dykim18 Modifications, Alterations and Updates 0 08-28-2012 01:53 PM
rivet rivet kayleigh0302 Modifications, Alterations and Updates 8 03-29-2012 02:51 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
