Burro ceiling - Page 2 - Fiberglass RV
Old 07-02-2011, 12:57 PM   #15
Pam Garlow's Avatar
Trailer: U-Haul 1985
I'm using red and considered a red headliner also, but decided to go neutral so that I could change colors in the trailer without changing the headliner.
I glued up bubble insulation and spray-glued a grasscloth rollup blind on it. (it took 2 blinds). Easy to cut to fit with scissors. Then I finished the edges with trim that I hot glued into place.
Old 07-02-2011, 04:45 PM   #16
Green Frog's Avatar
Trailer: '83 Burro
Virginia
That looks really sweet! Somebody else was doing bamboo shades the same way. I guess a tropical theme would suggest using our little Burros for the ultimate getaway. Now where did I put my inflatable parrot!
Froggie
Green Frog is offline   Reply With Quote
Old 07-31-2011, 04:47 PM   #17
spudfriend's Avatar
Trailer: UHAUL
Question
Originally Posted by Patricia LW View Post
I think you are going in the right direction keeping the color neutral. I think if you were to put a contrast color (dark) it would feel like the ceiling was closing in on you. Keeping it a color similar to the white will lift up the ceiling. I will be interested in what you decide on.
I am thinking I will use marine colors because those are pleasing and relaxing to me. It all depends on how expensive the canvas is.
Pat
We picked up some indoor/outdoor low rise pile carpet from Lowes for cheap, how thick on a headliner is too thick? Ours measures...1/4 inch thick.
spudfriend is offline   Reply With Quote
Old 07-31-2011, 04:48 PM   #18
spudfriend's Avatar
Trailer: UHAUL
Question
Our headliner channel isn't perfectly square from one end of the trailer to the other (front to back) it actually starts out at 22" goes up to 24 inches for the majority of the width to the back and tapers to 23" just above the rear window on our '85 UHaul CT. Would that be a problem with using this type of headliner?
Old 08-01-2011, 02:15 PM   #19
Trailer: in the market
We are working on the roof issue- need adhesive help!
We also stripped the carpet off of the 83 Burro we bought as soon as we had it home. It was stuck on with liquid nails, which softened nicely in the heat, and made the job easy. We want to add a layer of the reflectix insulation and then something similar to the bamboo treatment we have seen on previous posts. We need help with the adhesive, though. Does anyone have a suggestion for an adhesive that works well in extreme heat? It is over 100 degrees here, and that is usual in the summer time. I am tempted to use the liquid nails again, but does anyone know of something that worked better? We have the wide gap area to cover.
Dana in Texas is offline   Reply With Quote
burro
ceiling fans, and batteries Peggy Electrical | Charging, Systems, Solar and Generators 25 07-26-2007 06:57 PM
Carpeting On The Wall & Ceiling? Cathy P. General Chat 9 02-18-2007 07:47 PM
ceiling tape on 70's Surfside? eilie Care and Feeding of Molded Fiberglass Trailers 2 07-02-2006 10:01 PM
Boler ceiling vent wanted Dan Simon Classified Archives 1 04-24-2006 10:32 AM
Ceiling vent leak Dan Simon Problem Solving | Owners Helping Owners 2 04-13-2006 08:11 AM
» Trailer Showcase
NO YOKE
Ron F
Yeti
RV Doctor
