10-22-2007, 03:39 PM
Trailer: Casita Spirit Deluxe
I have calcium spot about 4 years worth...my sprinkler hits one of the back corners of the Casita....thoughts on product that will renew the fiberglass???
Thanks
Larry...Sacramento
10-22-2007, 03:59 PM
CLR® (Calcium, Lime, Rust Remover) should work and wouldn't be harmful to the fiberglass... it works on plastic showerheads. You can find it in most grocery stores.
10-23-2007, 07:05 AM
Trailer: 1990 Bigfoot 5th Wheel
Vinegar will take off most calcium deposits.
10-26-2007, 11:47 AM
Thanks a lot Donna!!
Larry
10-26-2007, 06:22 PM
Hi: We have hard water but it usually doesn't start till mid Dec and is gone by late March
10-28-2007, 09:39 AM
Trailer: Boler 1984
Alf I thought our HARD water was when the prop blade on the boat hit the sandbar.
10-28-2007, 05:27 PM
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Thanks
Larry...Sacramento
We like Lemi Shine. Makes work very easy.
It was designed for dishwashers, but if you read their website it talks about many other applications. Basically any where, where there is Hard water calcium deposits.
http://www.lemishine.com/
Click on the “Do You Have Hard Water” button and scroll the window to the right.
11-03-2007, 05:35 PM
When I lived on the West Coast of Florida, the sandbar solution was to have a stainless steel prop because they would stand up to grinding on the sand much better than the aluminum ones. Then I went down to the Keys and saw wading birds too close to the boat and found out that coral trumps stainless...
11-04-2007, 01:23 PM
Thanks for the reply...I tried CLR...worthless
Then a guy that works on fiberglass told me to use 3M, 401Q Imperial Wetordry paper A Wt....PERFECT...used it then added polish back on it.
Now on a more regulare basis i'll clean off the spots with my CLR then once it's gone I'll try what you suggested..Lemi Shine
Thanks again
Larry...Sacramento
11-04-2007, 04:47 PM
Just a word of advice -- If you use abrasive stuf, like most polishes actually are (read label carefully; they make the surface shiny smooth by removing part of it), often then you risk marring the gelcoat. That's especially true if your use is confined to just one area and even more true if you use machinery....
I see a distinct correlation between friends who own/use electric polishers and early surface deterioration on cars and boats.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
our secret spot
CharlynnT |
Camping, Campout Reports |
2 |
05-16-2008 08:31 PM |
Great spot to relax at
Chester Taje |
2 |
07-29-2007 04:42 PM |
Tight spot
Greg Yother |
17 |
04-16-2007 06:30 AM |
bright spot
Legacy Posts |
Rallies, Get-togethers, Molded Meets (Archive) |
3 |
06-16-2003 09:34 AM |
A perfect spot for Charles
Legacy Posts |
11 |
04-08-2003 10:55 AM |
