Camco RV Blow Out Plug - Fiberglass RV
Old 09-05-2015, 07:10 AM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
I get great ideas here and just read about this, so I bought one for next year. I already winterized before buying it.
I have a little walmart air compressor, but it's not oil-less as the directions indicate on the camco package. Not sure I get it...do oiled compressors always blow out traces of oil in use, or is this just running the risk of if the compressor blows up, it'll blow oil down your lines?
The blow out plug was cheap, but I'll be bummed if I can't use it. I know little compressors are cheap at harbor freight, but I don't want to buy a new one for this as all I ever do is blow up tires and/or other simple jobs such as this.
As always, cheers!
Wendy
Old 09-05-2015, 08:55 AM   #2
Does the compressor have a regulator/oiler/water trap on it? Some compressors have the oilers to keep tools like grinders and other air tools oiled. I dont have one on mine (it's not a Walmart). But I do have a water trap to protect moisture from coming through the line.
I will say this, IF oil is coming through, DO NOT use it to blow your water lines out. One is, HEALTH...especially if you drink the water. Another thing is, if you get oil in your water lines, it will be VERY difficult to get it removed...if you can get it removed. Never heard of it happening so you would have to Google it to see.
My preferred method of winterizing on my 13' Scamp:
1) Make sure you drain all the tanks INCLUDING the water heater and waste tanks.
2) Make SURE your water heater is in "bypass" mode.
3) Put a gallon of (I use -50 Camco Artic Ban) *edited* RV antifreeze into the fresh tank. Turn on the pump and I turn on the bathroom faucet first then the shower head. I run the "drain" pump as well as it will add antifreeze to the drain system. I run this in the toilet. I do the kitchen sink faucet as well.
4) I also winterize the "Hot" water lines by opening the hot water valve at both sinks; put my finger over the faucet; turn on the cold water and it will literally push antifreeze into the hot water lines and back to the water heater. Again, I do the same at the bathroom sink.
5) This will take exactly 1 gallon...or always has for me. Then, with the water pump off, I go outside at the "city " inlet, press on the little button up in the inlet (1-way valve) and the pressure that is left in the system will shoot out the remaining water there and I usually see a little antifreeze.
6) Then you can drain your tanks again. I've done it both ways. But one thing for sure, if you dont drain the gray tank, you will have about 3/4 gal of antifreeze sitting there protecting the valve.
Almost 6 years and not one problem. I have blown the lines out first, but with the method I just described it isnt absolutely necessary.
Darral T. is online now   Reply With Quote
Old 09-05-2015, 09:31 AM   #3
Ian G.'s Avatar
The key to blowing out water lines is a large volume of air at a lower pressure. You need enough volume to force the water out, most small compressors are very low volume with higher pressure, so a small or tank-less compressor will not work. You may find the a good vacuum cleaner connected to "blow" will work better than a small compressor. Here is the process I use http://www.proud-canadian.com/making...v-water-lines/
Ian G. is online now   Reply With Quote
Old 09-05-2015, 11:08 AM   #4
Roger C H's Avatar
Exclamation Peak antifreeze?
I hope that they make and you use the PINK antifreeze. Regular automotive antifreeze is POISONOUS. Be sure to only use the pink made for potable water systems.
All we have to clear is the drain line for the sink. I use a small, dedicated plunger.
Old 09-05-2015, 11:17 AM   #5
You're exactly right-- *RV* Anti-freeze regardless the brand!! Thanks Roger.
I also corrected my original post- while Peak DOES make RV Antifreeze, I actually checked my stash and I use what our local Ace Hardware runs on sale- Camco Artic Ban. -50 deg rating.
Old 09-05-2015, 11:24 AM   #6
Roger C H's Avatar
Smile Thanks
Thanks Darral. We always have to aware that newbies read these posts and we have to be specific where there is a chance of misunderstanding. The biggest problem when getting into a new field of endeavor is to learn all the 'common knowledge.'
Try sailing where every line (rope to landlubbers) has a name.
Old 09-05-2015, 11:27 AM   #7
I'm not sure if you're referring to "small" compressors with or without tanks, but I use a small 3 gal tank, oil less compressor wih no problems. Just make SURE the pressure is NOT set over 40-50lbs or you could blow some internal hoses!! The actual safest way to me...is the RV antifreeze.
Harbor Freight makes the same compressor I have. But mine is actually the Sears "Evolv" brand. I only gave about $59 for it. From this URL, it looks like they've grown very fond of the little nugget! The Sears DOES come with the little air nailer- works well too.
Sears: Sears.com
Harbor Freight: Pancake Air Compressor - 3 Gallon, 100 PSI
Old 09-05-2015, 02:38 PM   #8
CampyTime's Avatar
No it does not Darral. It's just a cheapo Campbell Hausfield. Maybe 120 psi max.
Old 09-05-2015, 07:31 PM   #9
Ian G.'s Avatar
The key is you need to sustain an airflow for enough time to purge the water from the lines, in your case 3 gallons has proven to be enough whereas in another trailer the lines my be longer or the line are installed where a larger volume of air is needed to completely purge the water from the lines. Another consideration is your climate, I notice you are in Tennessee where it does not get the sustained cold weather we experience in western Canada. The important point is that the air volume has to be enough to purge all the water from the lines, also a number of manufacturers recommend limiting air pressure to 30 psi, higher pressures can cause damage to the system.
Old 09-06-2015, 08:18 AM   #10
Good point Ian. I see a Boler in your profile pic? But a 19' Escape.... So, I can definitely see where for a larger RV, mine compressor might not be enough. Never tried it so I cant say...and no...we dont have the severe winters as Canada. Thus, is why I wouldnt risk just doing air. I'd do both the air AND RV af.
Old 09-06-2015, 08:46 AM   #11
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Rather than the Camco adapter, which does not have threads, I prefer a homemade adapter that has an air hose connector in the input & a standard hose thread fitting on the other.
The advantage is you don't have to hold a air hose chuck on the adapter like you do with the Camco. Lets you connect a 30 - 40 PSI source to the trailer & go through the various faucets, opening them one at at time to blow out the water. I do the entire process twice waiting a day between to be sure I got all the water. It also allows solo winterizing. I've used air only for the last 3 - 15F winters with no problems.
Old 09-06-2015, 12:34 PM   #12
Camco makes one of those as well. I didnt get it from Home Depot but this is the one I have and it works fine.
Camco Blowout Plug with Quick Connect-36143 - The Home Depot
Old 09-06-2015, 07:14 PM   #13
CampyTime's Avatar
I'm going to try and find a link to my compressor, if it's still available to see if you folks think it would be ok to use and give it a try next season.
Old 09-06-2015, 07:20 PM   #14
CampyTime's Avatar
I hope that link works below. That's my compressor. Please let me know if you think it's safe to use with this camco blow out thingie!
Cheers,
Wendy
http://www.aircompressorsdirect.com/...FcGRHwodwhYHZA
7 way plug to 4 way plug back to 7 way plug immrbill Problem Solving | Owners Helping Owners 3 08-10-2015 11:08 AM
Blow out on the freeway MCDenny Towing, Hitching, Axles and Running Gear 114 01-09-2015 01:49 PM
A Better DIY Adapter to Blow-out Water Lines Ian G. Care and Feeding of Molded Fiberglass Trailers 6 11-03-2014 01:26 PM
trailer windage in a blow--Will it stay upright? rabbit Care and Feeding of Molded Fiberglass Trailers 17 08-29-2011 12:24 PM
HOW do you blow out your trailer water lines? Karalyn Plumbing | Systems and Fixtures 8 10-16-2006 07:18 PM
