Can I celebrate? (And a question on fridges) - Fiberglass RV
Old 05-29-2016, 08:21 AM   #1
Trailer: 1979 Scamp 13'
Talking Can I celebrate? (And a question on fridges)
my fridge works on propane!! woohoo
Last fall we bought the scamp, but haven't had time to check the propane line/fix it up until this weekend, which is FIX UP THE SCAMP weekend. We'd tried the fridge on AC, and it wouldn't cool. No battery yet/not even sure we will use it yet, so haven't tested that.
So SUPER excited that the old travl'r fridge in the 1979 scamp works. That's like a bonus as we assumed it didn't on purchase!! Plus it has a freeezer area unlike the cheaper modern ones and doesn't need the battery to run.
If anyone has any ideas why it won't work on AC, I'm all ears. But, for our style of calming, I'll take propane working!
Zennifer is offline   Reply With Quote
Old 05-30-2016, 06:37 AM   #2
Hi Jennifer,
What make and model of fridge is it? Check your heating element.
Larry Engelmann is offline   Reply With Quote
Old 05-30-2016, 06:52 AM   #3
Administrator
Mary F's Avatar
I know this is really obvious, but are you sure it's plugged in? The outlet is probably in the back, accessible from outside. Yours wouldn't be the first to have been unplugged...
The reason I ask is it seems odd that it will work on propane but not 110v AC.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 05-30-2016, 07:39 AM   #4
You know, I'll check on if it's plugged in. . Wouldn't that be funny!
It's a Travel'r Elixir
Old 05-30-2016, 07:48 AM   #5
While you're checking the plug, verify the outlet actually has power.
If all that checks out, then I agree with Larry- I'd suspect the heating element.
Old 05-30-2016, 09:58 AM   #6
It is not unusual at all for any of these three way fridges to work on propane but not on either of the DC/AC.
Old 05-30-2016, 12:11 PM   #7
It was plugged in. need to check that that plug is working, of course.
And if it's going to work on only one, I'll take the propane hands down!
Old 05-30-2016, 12:35 PM   #8
If it works on propane, then getting it to work on electric should be fairly easy and inexpensive. You will likely want that so you can pre-cool the fridge at home for 12-24 hours before heading out without burning gas (assuming of course you are stocking it for the trip and not only at your destination).
And seeing the age of your trailer, I have to wonder if the gas side of your fridge is due for some cleaning and routine maintenance.
Old 05-30-2016, 01:49 PM   #9
How do you know it didn't (doesn't) work on electric? How long did you leave it on electric before you determined it didn't work? Were you expecting it to make noises like your home refrigerator (it doesn't). Was the trailer level... I mean really level when you tried?
It's easy to tell if it works on propane due to being able to view the burner in action. The electric portion, only time will tell... and sometimes that's really, really slow.
Old 05-30-2016, 02:05 PM   #10
We left it on about 3 days...no change. Trailer perfectly level at the fridge (surface level inside).
Old 05-30-2016, 02:06 PM   #11
I think everything is due for some cleaning and maintenance! Is there anything special that needs done to the fridge propane parts?
Old 05-30-2016, 07:52 PM   #12
Found the info I need for the fridge maintenance in another thread. Project for tomorrow!
Old 05-31-2016, 12:07 AM   #13
DougOlson's Avatar
The frig in my Scamp seems to be less sensitive to level on propane than AC power. When I run it on AC I have to be sure the trailer is very level.
Sent from my SM-N900T using Fiberglass RV mobile app
DougOlson is offline   Reply With Quote
fridge
12-volt marine fridges with the Danfoss compressor Loren G. Hedahl General Chat 13 04-05-2008 05:27 PM
propane fridges Michel pouliot Care and Feeding of Molded Fiberglass Trailers 27 07-25-2007 10:26 AM
Old fridges Peggy Care and Feeding of Molded Fiberglass Trailers 25 07-03-2007 11:13 PM
norcold fridges FYI General Chat 0 12-31-1969 07:00 PM
