Can Windows be Switched Out? - Fiberglass RV
Old 09-12-2012, 09:38 AM   #1
Trailer: Burro 13'. 1982
Montana
I'm thinking about switching out my Burro rear window for a Scamp slider to get more air. Has anyone done this? Is it possible? Found one that is 18 x 42 inches.....
Lfoxmont is offline   Reply With Quote
Old 09-12-2012, 10:47 AM   #2
Pam Garlow's Avatar
Trailer: U-Haul 1985
I think that someone did that with a UHaul back and front window. In that case, the UH window was slightly smaller than the Scamp, so they just needed to make the fiberglass hole a little larger and make a minor adjustment to the inside clamp ring to install it.
Old 09-12-2012, 02:01 PM   #3
I'm one of those someone's that did it with the rear window in our Uhaul. I had to widen the opening by about 1/2" each side and round the corners a little. Also had to put the clamp ring on backwards. Scamp did a great job boxing the windows. I got the rear and one side window, $160 for the rear, $152 for the side, shipping was $60. You really can't tell how it will fit until you get your old window out. I have the following measurements that I took for the rear. My original opening was 41 3/8" wide, 18 1/8" high. The Scamp window needed an opening of 42 3/4" wide and 18 1/4" high with a 3" radius corner. Scamp sent the clamp ring and some sticky back foam tape. You're probably better to use the butyl putty tape rather than what Scamp provides. I couldn't get the window flange to draw up tight, and it probably didn't leak because I also used some adhesive sealer too.
windows
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Difference between automatic demand and switched pumps GordM Problem Solving | Owners Helping Owners 4 04-12-2011 04:52 AM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
Which Windows? RachelW General Chat 11 06-25-2008 05:17 PM
Do you do windows? Legacy Posts Problem Solving | Owners Helping Owners 6 08-06-2003 08:00 AM
