canopy shelter for camper - Fiberglass RV
Old 08-14-2018, 01:14 PM   #1
Trailer: 2013 13' Scamp
Maine
I have been looking high and low for some type of shelter for our 13' scamp.
When at home, our best place to park the Scamp is under a pine tree (of course). Being our first full year with this 2013 Scamp, we noticed a lot of sap on the camper. We just finished using the Meguire's 3 part fiberglass restoration (see other post), and we did not want to re-do all that work any time soon.
We decided on the shelter logic 10 x 10 that has open gable ends. Target had 10% off, so we scored this for $90 delivered.
We can easily move the canopy out of the way when we want to take the Scamp out for a trip, we can get in & out easily, and we can take it down and for winter (we use another cover).
After getting this up, we can see that it needs some small reinforcements, so we will probably put some pvc pipe around the downrods, just to make sure they don't bend. We will also duct tape the 2-piece downrods to make sure they stay together (have read reviews where they come apart). Since we want to take it down in the winter, we will not rivet these 2 pieces of the down pole together.
It is only 1 day into having this up, but definitely happy to have our Scamp covered from the Pine Tree droppings and keep our nice fiberglass polish in tact !
2013 13' Scamp
2013 Subaru Outback
MrJohn is offline   Reply With Quote
Old 08-14-2018, 01:35 PM   #2
Trailer: 2008 Casita 17 SD
My next door neighbor has a couple of huge fir trees, (you can see one of them on the right in the first pic,) and dripping sap is all these trees seem to know what to do. I bought, and had installed, a metal carport to cover my whole driveway. My wife doesn't like sap on her new Chevy Silverado either, so selling her on it was no problem.
Old 08-14-2018, 01:36 PM   #3
We used one of those over our Uhaul before we got all the leaks fixed. Instead of duct tape you could drill a hole at the joints and put in a sheet metal screw.
Old 08-14-2018, 01:45 PM   #4
Trailer: 77 Scamp 13
Ours gets road black. Dust from tires with the oil from the road leave streaks where water drains. So I could see a $90 cover as a good deal. But would wonder how it will do in winter.
Old 08-14-2018, 03:49 PM   #5
I use a 12' X 30' shelter logic at home. Make sure you anchor it down. I also used rope under the canopy to tie the structure together so tubes cannot pull out from each other. the top lasts me about 4 to 5 years in the socal sun. no real rain to speak of and absolutely no snow to worry about.
Old 08-15-2018, 01:15 PM   #6
Trailer: 2001 13 ft Scamp
How would this work for shading the Scamp when camping? Our Scamp doesn't have ac.
DJLEE is offline   Reply With Quote
Old 08-15-2018, 01:48 PM   #7
I..
We decided on the shelter logic 10 x 10 that has open gable ends. Target had 10% off, so we scored this for $90 delivered. ..
I got the 20 foot long Shelter Logic temp carport.. It appears to be the same as yours except for the length and six supports instead of four.
I did not use any of the garbage anchors that came with it. Instead I used anchors that are much more sturdy, including concrete anchors for one side that is next to a concrete driveway. It came with four anchors for the four corners but I also added anchors and rope to the middle supports. I also added a few diagonal supports ropes including two that go from the roof to the opposite corner anchors at the back. Furthermore I added sheet metal screws to most of the joints.
So far so good.. its been up since March. A good snow or hail storm with still trash it and high winds might do it in also, but at $100 it can be replaced many times for the cost of a car port. That is assuming it does not damage the Scamp when it flies away.
Expect it to take a few hours to set up. With the extra I did, it took all day.
Old 08-16-2018, 12:01 AM   #8
Maine
These are reallly good tips! Things i have not thought of. Thanks a bunch!
I wish I could get @Casita Greg’s setup !
2013 13' Scamp
2013 Subaru Outback
Old 08-16-2018, 12:57 AM   #9
Borrego Dave's Avatar
Trailer: Casita SD17 2006
[QUOTE= I wish I could get @Casita Greg’s setup ![/QUOTE]
Ain't nothing but a thing and a check to fix that John .
Old 08-16-2018, 06:05 AM   #10
For the OP I think you might be right. It looks like he has room for a nice carport, and if it were me I would spend the money for one.
But perhaps his situation is like mine. A permanent carport is not possible here because of geography and zoning, so I have a temporary one that I am hoping is not too temporary.
Old 08-16-2018, 01:11 PM   #11
Trailer: 2018 Casita Spirit Deluxe
OR
Gordon: do you think that the Shelter logic will work for my 17' Casita SD??? I am thinking it may be taller than a Scamp but don't really know about that.
thx
karwask is offline   Reply With Quote
Old 08-20-2018, 07:21 AM   #12
thx
I would think so, at least until the shelter comes down
I thought the Scamps were taller but I don't know for sure.
I measured about 8' 9" height with my roof A/C, and it fits in the shelter fine. IIRC it's 10 feet to the peak of the roof. The poles on one side of mine are on blocks and so about 12 inches higher, but even if they were at ground level the Scamp would fit.
Old 08-25-2018, 12:33 PM   #13
Trailer: 17’ Casita Spirit Deluxe
new Canopy idea
I started with a 10’x13’ sail (10' x 13' Sun Shade Sails Canopy Rectangle Sand, 185GSM Shade Sail UV Block for Patio Garden Outdoor Facility and Activities Sold by: Artouch Direct). -- For the Poles, I intended to cut a heavy dowel into manageable pieces but only found square 8’ 2x2’s @ Lowe’s(or wherever). Cut into pieces 4’ x 4’, then added another 2’, for 10’ height. Originally I used double-threaded molly bolts to connect the pieces, as seen in pic, but I feel like I’ve improved the ‘design’ since last weekend, and now connected the pieces with hinges, and then toggle latch clamps (2 of Anndason Toggle Latch Clamp 4001 ,100Kg 220Lbs Holding Capacity (6PCS) Sold by: Anndason), with a bolt on top to thread into the corners of the sail, and also around which I loop the guy wire around in the other direction. The strength of it comes from anchoring the corners using guy wires connected to the camping stakes (Guyline Tensioner Kit by Tent Tools | 50ft Ultra Reflective Tent Rope with 10 Aluminum Guyline Adjusters | Incredible Strength & Safety in One Package). This latter package btw is really TOPS for the price! You want at least 11” stakes depending on the soil.
and for the polls I submitted a picture of my set up as-is with bolts inside but since I have changed to the second way of connecting the 4 foot segments of 2 x 2 poles. -Ian McAdams
AF0636A9-8B81-4857-AA71-3E748026DF98.jpg   3A76D5FA-2857-4B8D-9B0F-97EDF528261C.jpg
05A2D4B2-9A16-420F-8927-07106D973B57.jpg   93F02657-9407-4917-A649-49137C102C4A.jpg
ianmcadams is offline   Reply With Quote
Old 08-27-2018, 07:28 PM   #14
Maine
@ianmcadams that is some good ingenuity on the poles! Nice work!
2013 13' Scamp
2013 Subaru Outback
New canopy for Egg Camper cpaharley2008 Care and Feeding of Molded Fiberglass Trailers 38 04-15-2016 07:03 AM
shelter john warren Care and Feeding of Molded Fiberglass Trailers 23 11-04-2012 06:33 PM
Truly Instant Shelter Francesca Knowles General Chat 3 07-30-2011 07:27 PM
Free standing shelter: Compact junior Kent I Problem Solving | Owners Helping Owners 19 11-11-2008 11:12 PM
EZ UP/First Up/Shelter Logic/Coleman products ??? DanPatWork Problem Solving | Owners Helping Owners 4 07-20-2008 09:24 PM
