Casita Insulation ?? - Fiberglass RV
Old 08-20-2008, 05:19 PM   #1
Jimmy M.'s Avatar
I recently toured the Rice, TX Casita factory ... the workmanship and design was VERY impressive, to say the least ... the lady that showed me around was very knowledgeable, and no sales pressure whatsoever ... 60-day waiting period for delivery, they are building them as fast as they can ... however, my research shows that foam-back carpeting's insulation R-Value is virtually non-existent (R 1.2-1.6) ... am I missing something here ? ... while I'm not planning on any arctic trips, I do like to stay warm, etc. ... how is the Casita in the winter ? ... thanks in advance
Jimmy M. is offline   Reply With Quote
Old 08-20-2008, 11:25 PM   #2
Jimmy M,
The insulation actually does a good job. A small electric cube heater equipped with a thermostat works well to keep one comfortable below freezing temps. The factory supplied Coleman AC does the cooling job even at 105 degrees F.
If I had my "druthers" I'd like dual glazed windows, but to my understanding, they aren't available or weren't in 2000.
Kurt & Ann K.
Old 08-21-2008, 05:45 AM   #3
Have stayed in weather as low as 28 deg F. No problems keeping warm. I did have to open all the lower cabinet doors to keep the pipes from freezing. I considered this a small annoyance.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 08-21-2008, 06:46 AM   #4
Administrator
Mary F's Avatar
The Winter Camping article (see "nav bar" on the left of each screen) is about camping in a Casita, in Illinois.
I'd say the carpet doesn't have much of an R-factor, but the space is so small, it doesn't take much of a heater to keep it warm. We always had trouble with being too warm in our old 16 footer, with the little cube heater going... That's camping with electrical hook-up, of course.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 08-21-2008, 11:36 AM   #5
David and Nancy's Avatar
Trailer: Bigfoot 25 ft (25B25RQ)
I was living in Alaska when I had my Casita, so the climate doesn't apply to most Casita owners. I found that when camping at temps below freezing the furnace cycled on and off very frequently. This will quickly draw down a 12v battery when boondocking, so you need a power source. However, it did stay quite comfortable in temps down in the teens. The "heat strip" on the AC unit was not adequate to maintain comfort in those temps. Off course, the plumbing starts to be an issue at that point, too.
After moving to the lower 48, I continue to frequently camp in sub freezing conditions. Such as high mountains of Colorado, and hunting camps in winter closer to home. I ended up getting a Bigfoot because of the better insulation and protected plumbing. The insulation and the double-pane windows on the Bigfoot do maintain interior temps much better. However, most people don't really want to go camping in freezing weather and probably have no reason to spend extra money on a 4-season trailer. The Casita is a great 3-season trailer, but not ideal for true winter camping. I understand that the Oliver can be purchased with thermal pane windows and enclosed plumbing, too. Not sure of their insulation value. But there again, that unit costs about double a Casita. I also used in old Scamp in Alaska. Basically the same insulation as a Casita with the same results.
David and Nancy is offline   Reply With Quote
Old 08-21-2008, 07:58 PM   #6
Jimmy M.'s Avatar
OK, that pretty well answers my question ... thanks, folks
Old 09-14-2008, 06:36 PM   #7
Jimmy M.'s Avatar
well, I guess I'll deal with it OK, my semi-trucks weren't insulated much, either ... I will be picking up my new 2009 Casita 17' Freedom Deluxe mid-October, and getting anxious :banana
casita
Ensolite insulation Mark LL Modifications, Alterations and Updates 2 12-02-2009 03:43 PM
Insulation Rick T Problem Solving | Owners Helping Owners 8 03-22-2009 06:56 AM
Question on Insulation Michelle Hochachka Problem Solving | Owners Helping Owners 1 10-06-2007 04:54 PM
burro insulation Jason L. Problem Solving | Owners Helping Owners 2 01-12-2006 06:47 PM
Insulation Willie Brown Ft. Langley B.C. Rallies 0 12-31-1969 07:00 PM
