We have a new to us 2000
Casita. The original owners purchased it, used it a bit the first year, and then it sat. When we bought it the 2000
license plates were still on it. It has absolutely no evidence of wear anywhere but does show yellowing on some of the plastic bits from age/heat. The shower curtain falls to pieces when you breathe on it
The
tires have already been replaced. We're in the process of checking out the systems - replaced the AC shroud, replaced the vent cover, replaced the water heater anode rod and drained the tank, testing the water pump, replacing the
battery. We need to take the
propane tanks in and have them checked & filled.
If you were us, what else would you recommend we check/replace? What bits of a
Casita need replacing just due to the passage of time?
