caulking of belly band - Fiberglass RV
Old 06-20-2016, 09:50 AM   #1
morgynm's Avatar
Nova Scotia
My Boler's belly band has white caulking at the edges and I noticed that it was starting to get cracks in it. Do I remove all the old caulking before applying the new stuff? Last time I neatly caulked anything was our new tub... and maybe a window here and there... and that was probably 10 years ago!! I remember wetting an old spoon to smooth the caulking but that's all I can recall!
morgynm is offline   Reply With Quote
Old 06-21-2016, 10:43 PM   #2
Trailer: Still Looking
Alabama
You should always remove the old first. The new won't adhere to the old very well. Also by getting the old off and out, it gives new key and tooth for the new to grab on to. If you have some on the gelcote you can use a small piece of mica to remove it without scratching the finish. Then use denatured alcohol to clean it before applying the new.
Bullington is offline   Reply With Quote
Old 06-22-2016, 05:36 AM   #3
We always recommending removing any old caulk or butyl before applying new. Nothing worse that a blobbed ugly mess going forward.
Do NOT use silicone on the exterior of your all-molded-towable.
Best of luck!
Old 06-22-2016, 08:46 AM   #4
morgynm's Avatar
Nova Scotia
I bought DAP 230. I'm hoping that is the correct stuff!!
Little Mold pinpoint spots on caulking before belly band CampyTime Care and Feeding of Molded Fiberglass Trailers 14 08-30-2015 05:49 PM
Caulking above the belly band? artrageous Modifications, Alterations and Updates 8 04-29-2015 03:34 PM
Caulking the belly band of my Boler Emilie W. Problem Solving | Owners Helping Owners 18 02-28-2015 06:28 AM
13' Scamp caulking around metal band DavidS Problem Solving | Owners Helping Owners 4 11-28-2011 04:18 PM
Belly Band Leaking? Isaac M Problem Solving | Owners Helping Owners 23 05-17-2006 10:06 AM
