CHECK LISTS - IíLL SHOW YOU MINE - Fiberglass RV
Old 11-30-2002, 01:59 PM   #1
:wave***Arrival Safety Checklists
EXTERIOR ARRIVE CHECKLIST:
1. Car-Trailer electrical plug disconnected
2. Unlock trailer door
3. Pull out steps
4. Remove front window gravel shield
5. Stabilizer jacks touch-down and locked
6. Place wheel chocks (2)
7. Disconnect safety chains and stow
8. Install front jack wheel; touch down
9. Unlock tongue padlocks (3)
10. Unlatch and remove spring arms (2)
11. Remove anti-sway bar
12 Unlatch ball latch
13. Unlock and remove hitch shank; stow
14. Position trailer as desired
15. Place ground blocks under jacks (2)
16. Level trailer
17. Secure feet on stabilizer jacks
18. Connect 110 VAC shore power
19. Check fresh water supply; top off if necessary
INTERIOR ARRIVE CHECKLIST:
1. Turn refrigerator on to 110 VAC
2. Open roof vents, as needed
3. Start fan or heater, as needed
4. Open windows, as needed
5. Lower window blinds, as needed
6. Lights on, as needed
7. Mount TV shelf and TV8. Install flagpole
9. *Place outside doormat
10. Commence nap. (courtesy pjanits)
:wave**Departure Safety Checklists
EXTERIOR DEPART CHECKLIST:
1. Disconnect 110 VAC shore power; stow
2. Release stabilizer jack legs (2)
3. Stow ground blocks
4. Install hitch shank and lock pin
5. Position ball under coupler
6. Lower coupler on to ball
7. Close hitch ball latch and lock
8. Remove wheel chocks; stow
9. Raise tongue jack to highest position
10. Remove jack wheel; stow
11. Install spring arms into shank (2)
12. Latch chain link onto lift assembly (2)
13. Lock lift assemblies (2)
14. Install safety chains (2)
15. Install anti-sway bar
16. Secure steps
17. Install front window shield and lock (2)
18. Lock door
19. Access doors closed and locked
20. Trailer electrical plug connected
21. Final walk-around check
22. Test turn signals and brake lights
23. Test check brakes and controller
24. Check engine oil level
25. Check fluid levels
26. Clean windows
27. Pull forward 25 feet; check area for dropped items.
28. Depart
INTERIOR DEPART CHECKLIST:
1. Windows shut and latched
2. Blinds closed
3. Roof vents off and shut (2)
4. Cabinet doors shut and latched
5. Turn refrigerator to 12 VDC
6. All lights off
7. Table and counters clear
8. Food stowed
9. Fan or heater stowed
10. Radio/TV stowed
11. Storage tubs stowed
12. Outside chairs stowed
13. Wrap carousel in microwave
14. Flagpole stowed
15. Outside doormat stowed
16. Fold-up table stowed
17. Dump trash
18.*Turn off Potable Water Pump
Old 11-30-2002, 02:02 PM   #2
Missing items
Nice checklists Michael ... but your departure checklist doesn't say anything about putting the wife and dog in the tow vehicle.
I've learned from experience that they get pretty upset if you forget.
Don't do to Buddy and Lori what I once did to Pam and Maggie.
I really thought I was supposed to meet them at the dump station ... and that they were walking up there to meet me.
Old 11-30-2002, 02:41 PM   #3
:steer I have another one for beginners and people looking to buy a Fiberglass RV.
You can find it here: Buy/Sell Check Lists*****:u
Old 11-30-2002, 07:02 PM   #4
Forgot the most important thing
Michael,
Your forgot number ten on the interior arrive check list
10. Commence nap.
Old 11-30-2002, 09:49 PM   #5
:o pjanits,
OK, fixed.
Old 12-01-2002, 09:03 AM   #6
Todays Ziggy
I thought it was appropriate.
<img src=http://www.fiberglassrv.com/board/uploads/3dea32db4aac7zi021201.jpg/>
Old 12-09-2002, 02:04 PM   #7
interior depart check list,,, "turn off potable water pump and bleed water line pressure" I failed to do this once, and pumped the whole potable H2O tank onto the floor. Was my face ever red!
Old 12-09-2002, 04:12 PM   #8
:wave Jerry,
Thanks, it has added to the master list so people can print it out.
Old 12-09-2002, 05:14 PM   #9
order
Are these in order of doing? Now I realize that I don't have a sway bars so I don't know when those are disconnected, but I do know that there is no way I can unhook my trailer, postion, then chock it. we had a nice discussion of things we've done we shouldn't have, and not chocking before disconnect was one of the oops. so thought I'd check and see if order of doing could be adjusted, if that's important.
Old 12-09-2002, 06:34 PM   #10
Good observation Jana, :wave
How about making a new list in the order it should go and I'll post it at the top so everyone, that wants to, can print just the first page?
Make sense?:o
Old 12-09-2002, 10:42 PM   #11
list
Who Me??? :omy I don't camp enough to recreate an in order list, :u just enough to criticize someone elses. :reye2 maybe you need a volunteer:chased
Old 12-09-2002, 11:04 PM   #12
:weep :weep :weep Jana,
I hoped you would make me look good.
*********:nono ***:duck
Old 12-09-2002, 11:11 PM   #13
:wave Jana,
I fiddled with it.
Check it out and see if you see anything else.
THANKS.:chatter
Old 12-10-2002, 12:42 AM   #14
list
As I can't sleep because of this list running through my head, I'll work on a version. but I don't gar-ron-tee anything.
checklists
Buyers Check Lists james kent General Chat 5 03-10-2010 01:02 AM
Mine all mine! Bill D.D. General Chat 13 11-24-2008 10:48 AM
» Trailer Showcase
Beastie
BobB
Scamp 2
Mike L.
