Check this out NOT Poliglow...Time will tell.. - Page 17 - Fiberglass RV
Old 06-21-2011, 12:14 PM   #225
Sheryl's Avatar
Trailer: '99 Casita 17'LD
Montana
Originally Posted by rabbit View Post
If contemplating the plunge to floor wax, look back at Randy Bishop's pic of the Polyglow applicator in a very early post on this thread. It isn't cheap at 15$ but I'd say it's worth the cost to apply a very even coating. Polyglow recommends that it be washed out in water (and I used some Dawn liquid detergent), wrung out, and bagged airtight until it comes into play again for that annual recoat. I bagged mine and put it in the fridge; I hope it doesn't develop mold.
I like the slight "bronzy" color cast of the wax as against chalk white oxidized gel coat. Also seems to have made gel coat repairs and, dare I say it, expedient rattle can coverups disappear.
jack
Could you put it in the freezer instead?
Sheryl is offline   Reply With Quote
Old 06-21-2011, 04:15 PM   #226
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Duuh, I wish I'd thought of that. Sounds like a plan. Thanks.
jack
Old 06-21-2011, 08:46 PM   #227
Trailer: 1977 Boler
I have a varied assortment of un-washed latex paint brushes in my freezer already! Every now and then I'll throw them all out 'cause they'll dry out eventually.
Mark V. is offline   Reply With Quote
Old 07-02-2011, 07:23 PM   #228
Trailer: '74 Trillium 1300
Words of wisdom from a self confessed fool.
Make sure that your beast is a clean as it can possibly be and then clean it some more. The floor finish product seems to magnify every little (and large) blemish and stain.
Do not get greedy and try to do more than avery thin coat - if you get a run that you don't remove immediately then the next coat will solidify it not dissolve it.
Use an applicator that never drips - a cloth will do but make sure that it is folded so that a loose edge does not slop floor finish all over the egg.
These are things that I have learned - the hard way.
FGRV forums (or fora) are a truly wonderful resource.
Cheers
IanWR is offline   Reply With Quote
Old 07-03-2011, 01:09 AM   #229
ceilityme's Avatar
Trailer: 1973 Honey Boler...
Has anyone applied Redmax over paint? If so, automotive, marine, spray paint or otherwise. My boler has some graffiti on it, done with a marker, and I'd also like to change the colour and/or apply a design. Any thoughts? Thanks
ceilityme is offline   Reply With Quote
Old 07-03-2011, 07:28 AM   #230
cpaharley2008's Avatar
The RedMaxx works over decals so it should work over paint. Magic marker, I'd test someplace, it may come off unless you can seal it first. There is a Red Maxx #2 sealer that is part of the 3 part RedMaxx series with #3 used by everyone here. Possibly the #2 can seal the marker and then apply #3.
Old 07-03-2011, 06:26 PM   #231
rabbit's Avatar
Delaware
Yes, it works fine over "rattle can" touchup and fortunately masked the contrast of an ill-chosen white of very bluish cast on my Burro in progress.
Parenthetically, for those contemplating purist gel coat repairs, I have this advice. Be wary about Evercoat gel coat sold at marine stores. It cooks off damn skippy catalyzed to Evercoat's schedule and does same with MEKperoxide reduced to a quarter of the recommended amount. I threw away nearly thirty bucks on a pint of their gel coat and a bottle of PVA mold release to allow curing. You can speculate that I may have screwed up (and that's quite possible) but I had five yrs. of spraying gel coat in molds and hand layup back in the day (mid-70s) so I have just a wisp of experience and judgment of the stuff in question. This is the long way around to explain the spray paint over a bad patch of delaminated gel coat filled and faired in with body filler.
jack
Old 07-05-2011, 09:04 AM   #232
Trailer: 1973 Boler 1300 (gone) 1985 Bigfoot
I picked up a gallon of the Zep at Home Depot this past weekend and started on my 85 Bigfoot. Have only finished a bit fo the back (haven't got to the ugly parts like the front or the roof yet) but it seems to work well. Light scrub with scotchbrite and Spray Nine, rinse, let it dry and apply and it it really shines after 3 or 4 coats. I found the floor sealer dries really quick (in our arid climate) so I'm apply to apply multiple coats in fairly quick succession. I'll post some pics as I make some progress.
KeithA is offline   Reply With Quote
Old 07-05-2011, 06:23 PM   #233
Trailer: Fleetwood Jamboree MH
Hello! First time poster here at Fiberglassrv.com, and even though I own a class C motorhome rather than a fiberglass trailer, I wanted to share with you all my experience with Red Max Pro, as well as ask a few questions.
My motorhome was extremely weathered even when I bought it nearly 10 years ago. I had tried every type of wax, polish, gelcoat restorer, oxidation remover that I could find. Most did nothing other than lighten my wallet and give me a sore back & arms. A few gave so-so results that lasted a few weeks at best.
Then I heard about Red Max Pro through a thread on RV.net, and they had a link to this thread. Well, I was excited, to say the least. After 1 full day doing the prep (scrubbing the MH with Bar Keepers Friend, followed by a wash using TSP), I applied 4 coats of Red Max Pro (RMP) and WOW!!!! It has now been 3 months, in the hot SoCal summer sun, with a few thundershowers thrown in. It still looks fantastic. Here are some before (on the left) and after (on the right) pics. BTW, my painted metal cab was also in very bad shape, so it got the RMP treatment as well. Came out great! The whole coach shines like new, and it actually brought back the color that was so washed-out before.
Thanks to you all here at fiberglassrv.com, there was alot of info and discussion on Red Max Pro that helped convince me to take the plunge. Again, thank you.
So here are my questions. What have you all been using to wash your trailers now, that doesn't harm the Red Max? Have any of you noticed any yellowing, or any other "downside" to Red Max Pro?
Gary in SoCal is offline   Reply With Quote
Old 07-06-2011, 09:58 AM   #234
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
I wash mine at the neighborhood carwash with no harm to the REDMAX just make sure you "ONLY" use the wash and rinse cycle and "NOT" the tire cleaner or presoak soap..On one of mine I used the tire cleaner soap cycle and it just about stripped the whole thing, after it dried and I saw how bad it had stripped the finish off I went back soaked it again this time scrubber it a little in the hard to get places, then rinsed it and the remainder of the finish came off ..The next day reapplied 4 coats and looks as good as before..Don't know if the pre-soak soap will do the same I just didn't want to take any chances from now on..You will see later on that when it gets dirty the REDMAX makes washing you camper a dream most dirt will just wash off with plain water with very little scrubbing at all..HOPE THIS HELPS RANDY
Randy Bishop is offline   Reply With Quote
Old 07-06-2011, 04:11 PM   #235
Randy, thanks for the reply. I, too, had heard somewhere about the "tire cleaner" at car washes being a no-no. I've also heard that Windex with ammonia is bad; makes sense since ammonia is used to strip floors.
I've only washed mine twice since I applied the Red Max, both times with water only (first time just hosed off) since I was scared to use any soap for fear that it might dull the Red Max. But after 3 months, I'm very happy; it's already outlasted anything I had previously tried. A number of people have now reported that most normal carwash soaps are safe to use on the RMP.
One final question for you. You've now had the Red Max Pro on for nearly a year. How has it held up? Any downside?
We don't stop playing because we grow old, we grow old because we stop playing!
Old 07-06-2011, 07:54 PM   #236
Ardmore, Alabama
I haven't had one problem with it and 3 of mine have been through several snows this past winter which is VERY unusual for this part of the country, several days with the temperature's well over the mid 90's setting on a concrete slab baking and the humity around 98% with "NO" problems what so ever..I have heard that someone in Florida had a yellowing issue but he's the only one that has mention that and I know there are several people using the product now. I've been waiting to hear any problems people may have had but so far no one has spoke up with any issues..If there "were" any problems I really think this thread would have been bombarded with "ANY" dissatisfaction results they would have had..That's the great thing about this place if it works people post it if it "DON'T" work they post that also..there are very few shy people on here......
Old 07-06-2011, 09:16 PM   #237
Yes, in fact, it's earlier in this thread that the person from Florida claimed the problem with yellowing (rvrideout, on 4-29-11, page 14). What I found interesting about that was the fact that she joined this site 2 days prior to posting, posted just that one time, and then never posted again, in this thread nor any other. Kinda curious?
I know that before I took the plunge and used Red Max on my RV, I read everything that Google could find on it. We all know that complaints about products and businesses run rampant online; if there was any real negatives to using Red Max Pro on RVs, there would be plenty of online complaints. I was impressed with the fact that the only negative I found in all my research was that one post by rvrideout. Not only that, I actually found one very similar claim about "Poly-Glow" on a different site. I also found a claim by someone in the floor finishing business who stated that there is competition in that field and that yellowing is a thing of the past with today's floor finish products.
In any case, I'm a current believer in the stuff. I'll continue to watch for any negative results, but really don't expect any. With all of the research I did on it, reading how others have applied it, and also what I learned from my own application, I put together a kind-of step by step tutorial on the process that a number of users on the RV.net site have complimented me on. If you think it would be welcome, I can post it here as well, though I don't want to overstep my "place" here.
Old 07-06-2011, 09:38 PM   #238
Ardmore, Alabama
I believe it would be added bonus mayself and if any of the mod's think it shouldn't be here they will deal with it in their own way..So I say post it I would love to see how you did yours, I've done 5 so far and working on another one that even though I'm going to have to paint it because it was previously painted I'm going to still coat it with the REDMAX because it helps sooooo much when it comes to washing it...
poliglow
check out Emmitt G. Classified Archives 1 03-09-2010 01:33 PM
Check this out Kevin K General Chat 4 06-13-2009 10:30 AM
Check this out Kevin K General Chat 5 02-02-2009 10:07 AM
Hey Web Guy Check this out ! Glen G General Chat 12 02-20-2008 01:06 PM
» Trailer Showcase
Nubbs
spue
Doo Dah
RRoberts
