Check this out NOT Poliglow...Time will tell.. - Page 42 - Fiberglass RV
Old 04-02-2013, 12:13 AM   #575
Flygal's Avatar
I would not use a roller.
Flygal is offline   Reply With Quote
Old 04-02-2013, 01:30 AM   #576
camper407dm's Avatar
Trailer: 13 ft Casita 1985
Iowa
I would NOT use a roller or you will get streaks and running, from my experience.
camper407dm is offline   Reply With Quote
Old 04-02-2013, 07:15 AM   #577
arlon's Avatar
Trailer: 2002 Casita Bunk Delux
And here I'm dong mine with Ducky's and and an orbital polisher. I think I'll stick with the old fashioned way for now. More work but I know it will last if I keep a little wax on it. Since mine stays outside in West Texas sun, I'd be afraid of any kind of "coating". Obviously working for those that have tried it..
2002 Casita 17' Bunk Model Delux (replaced 28' 5th wheel)
2003 Dodge/Cummins quad cab (daily driver/tow vehicle of choice)
2005 AWD Astro Van/camper (my solo camper)
2006 Xterra MT (for sale)
arlon is offline   Reply With Quote
Old 04-02-2013, 07:38 AM   #578
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
No roller here. I used a microfiber cloth from the dollar store and 4 coats. Perfect!
Old 04-02-2013, 08:15 AM   #579
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
4 coats and microfiber cloth.
Old 04-02-2013, 08:59 AM   #580
Wallo's Avatar
Utah
Ok then, it sounds unanomous...microfiber cloth it is. I sometimes get hairbrained ideas, but check with those who have more experience before I experiment. I like the spray bottle idea. Tapeing off and covering the windows would prevent any overspray.
Thanks for your input.
Alice
Alice
Wallo is offline   Reply With Quote
Old 04-02-2013, 09:57 AM   #581
cpaharley2008's Avatar
looks great, Kevin.
Old 04-02-2013, 10:02 AM   #582
Thomas G.'s Avatar
Alice
It really goes on as a thin layer - not like paint. It is easy to wipe it around windows and other obstacles. And since it is clear, any mistakes are not readily visible.
Old 04-02-2013, 11:36 AM   #583
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
It occurs to me that a lot of floor wax devotees have either very small trailers, or very long arms, or they don't do quite all the top. I can think of no way to avoid the arms' length application of elbow grease to the process of cleaning and removing oxidized gelcoat from a trailer roof, whether with rag, sponge, or one-handed rotary buffer deployed as a scrubber.
The first and only time I did our Burro, I found working off a ladder and attempting to reach the center of a wet slippery roof wasn't particularly easy or safe. I settled on a section of scaffold alongside with a duckboard (plywood offcut roughly 2-1/2 X 5') projecting from the scaffold plank out onto the central Pullman section of the roof. This is the same system I've used to replace fans, vents, air conditioner gasket, and several other small thru-hulls atop the trailer. When cleaning, I moved this duckboard at least three times from end to end on each side. I would not want the bearing end of it to mark up newly cured floor wax nor do I want my feet up there spreading dirt and the sweat of my brow falling in wet wax.
The upshot is that when applying Red Max, I work to the centerline of roof from the scaffold plank with the PolyGlo chamois on a painter's extension pole and then move the scaffold back and continue to the bottom of the shell still retaining the pole extension where possible and detailing around windows, tail light recesses, vents and thruhulls with a small handheld chamois also provided by PolyGlo and practically equivalent to a microfiber rag. I wet out both chamoises in a paint roller pan and certainly err on the dry side when wringing out the hand chamois. I wear at least one nitrile glove on the hand that wrings out the chamois to avoid the absolutely shiniest clear nail polish you'll ever see on a man.
As a result of my experience, I feel compelled to ask if anyone in the happy microfiber faction has ever slipped and put a nice big handprint in their fresh wax or found themselves using an elbow or a knee as an applicator. I'm assuming that those who have either not bothered with what can't be seen from the ground or fallen to their death will not answer. The awkward roof situation I've described also prevails when applying conventional buffing waxes and employing a bonnet buffer. Given the general level of engagement with the minutiae of the mechanical arts that I see here every day, I am amazed that these difficulties are never mentioned???????
jack
Old 04-02-2013, 12:47 PM   #584
I did our 13' Lil' BigFoot with a ladder and leaned over the roof to do both sides of the centerline (about a 24" wide path) from one side only.
At least with the ZEP product, a quick respray and wipedown seem to take care of any handprints. The polimer (sp?) coating seems to reblend just fine.
Old 04-02-2013, 12:47 PM   #585
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I never had any difficulties with my scamp fifth wheel. I just leaned a ladder up against a window so I didn't get dirt on the fiberglass, and scrubbed 6" over the centerline the first side, then went to the other side. Waxing it was just as easy. I put 5 coats on in under 4 hours. I did wear gloves, that just seems to be common sense.
Old 04-02-2013, 12:55 PM   #586
Pipe insulation cushions ladder against trailer.
Old 04-02-2013, 01:57 PM   #587
Perk's Avatar
Trailer: U-Haul VT 16FT
When I did my 1985 16Ft U-Haul VT I had no challenges as you mentioned. I was able to repeatedly hand scrub and rinse up to the center line on both sides without a problem using a simple 6 ladder as seen in one of my pictures on this thread on entry #442. When I was initially scrubbing and washing, I sometimes held the center line ridge to give myself some extra leverage to scrub. But when I applied the 5+ coats of ZEP Wet Look I took my time using a damp micro rag to prevent runs and was able to polish up to the center ridge and never had a challenge . My VT still looks marvelous almost 9+ months later.
Perk
Enjoy the Adventure
1985 16ft U-Haul VT
Perk is offline   Reply With Quote
Old 04-02-2013, 02:08 PM   #588
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
2 words Sham Wow!
Seriously i agree with what Jack said and i have used both. The Chamois is superior for the final coats to get that killer shine. The Poly Glow applicator has its advantages but to save $ you can find synthetic Chamois at any auto parts store in the car was area relatively cheap, add a 4" wide 3/4 " or thicker board about 6 to 10" long depending on your grip,some 1/2" thick foam, wrap the chamois around so the seam is on top moisten with water and you are good to go. Being an ex pack rat Chemist i had an old squirt bottle that i used to feed the wax to the pad when it became dry, worked well, you could also use a trigger spray bottle just as easily. or you can mist a small area and use the pad to spread it out, finish up (5th +coats)using long sweeping light strokes for the best shine.
Michael J
mmeyer is offline   Reply With Quote
poliglow
check out Emmitt G. Classified Archives 1 03-09-2010 01:33 PM
Check this out Kevin K General Chat 4 06-13-2009 10:30 AM
Check this out Kevin K General Chat 5 02-02-2009 10:07 AM
Hey Web Guy Check this out ! Glen G General Chat 12 02-20-2008 01:06 PM
