Check this out NOT Poliglow...Time will tell.. - Page 51 - Fiberglass RV
Old 06-13-2014, 08:54 AM   #701
Roy in TO's Avatar
Bee,
I found Zep at Home Depot and Canadian Tire, it replaces the Red Max (same company different label). If you go the McGuires route I would still do the barkeepers friend first. It works as a precleaner and will give you a better result.
Old 06-13-2014, 09:45 AM   #702
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I haven't used Zep- still have some Poliglow so probably won't anytime soon. BUT... my problem is not sun, it is wind-driven sand. I'm wondering if maybe I hit the trailer with Poliglow twice a year if I wouldn't have to strip and start over every few years. It doesn't flake- it's just gone. I haven't redone it this year as I figured I'd wait until after my ocean camping trip and then maybe the finish would last until the winter winds hit.
Old 06-13-2014, 10:36 AM   #703
Roy in TO's Avatar
Originally Posted by Arizona Eileen View Post
Sorry, but I disagree about Zep. I used it and it'll keep your fiberglass looking new for awhile, but less than two years later my Casita developed horrible flaking all over, especially bad at the upper curve.
I wonder if what Eileen experienced is because her trailer is much newer than most of ours? I also wonder who is using the sealer first and who is not? Should we start a new thread to summarize techniques and results? E.g.:
  1. Trailer age
  2. # of coats of sealer
  3. # of coats of Red Max/Zep
  4. Length of time it lasted
  5. Location
  6. Stored covered or not?
I wonder if the ZEP "High Traffic" might be better for Bobbie, rather than using the "Wet Look". Once again I question the use of the sealer as a pre treatment. I consider it like using a primer for paint. Something that preps the surface and gives you a better bond.
Old 06-13-2014, 10:59 AM   #704
Well, I'm still going on PolyGlow until I run out (or learn which is the correct spelling- I use them all interchangeably.) I still have the prep stuff, too, so this time will strip and start fresh. (Also want to finally get my decals on.)
On an OT note, though- I tried a Zep product for cleaning tile, and man, that's the best stuff I ever used for old kitchen tile, hands down. I never found anything before that really cleaned up the grout but it was great.
Old 07-21-2014, 08:07 AM   #705
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Well just did my sunbaked 1998 Casita with a mix of Polyglow and Redmax that came with the trailer when we bought it. All I can say is OMG. I put on 5 coats after cleaning it with the polyglow cleaner mixed around 3-1. It brought the finish back from the dead. I used up what was left of the polyglow on the first 3 coats then switched to the Redmax for the last 2. The Redmax seemed to go on better but this may be due to getting a good base to apply it to.
I will post some pictures. It started to drizzle right after I did it so no pictures yet.
Old 07-21-2014, 08:49 AM   #706
North Dakota
Hello Dudley, good to see you are having "fun". Post some pics of the "old girl" when you can. I'd like to see it all shinned up. I'm enjoying my new Scamp.
Gene Masse is offline   Reply With Quote
Old 07-27-2014, 12:46 PM   #707
Rereading some (not all!) of this thread- but I think considering how long a quart of Poliglow lasts, I can afford another quart, and I already know it goes on easily and lasts. Sounds like Zep is harder to apply neatly? I haven't even looked to see if I can find it.
Old 07-27-2014, 01:22 PM   #708
North Dakota
One way to do it is to use the Zep for the first 3-4 coats and finish with the Poliglow. It's essentially the same stuff. They say the Poligolw has an ingredient to deal with the sun so if it's on the top tow layers that should be covered.
Old 07-27-2014, 01:29 PM   #709
Good idea. But I'd have to store the rest of a gallon of Zep. I'd rather store Poli Glow considering how much use I got from a quart.
Now I can't decide whether to wash and use Poli Prep now, and then do two coats, and wait for the rest to come, or wait until I can finish the job.
Old 08-02-2014, 04:49 PM   #710
Dudley's Avatar
Here are some pic of the Casita after the polyglow/Red max. Hi Gene , the trailer is coming along and yes we are having fun with it. The pictures don't do it justice!
Old 08-03-2014, 07:13 AM   #711
Trailer: Work And Play
I do not own an "Egg", but a fiberglass sided 5ver Work And Play. I bought it as a repo and am trying to get it more presentable. I will not bore you with all the work I have done trying to restore the shine, to the fiberglass, but internet searches have led me to you fine folks.
Last night while at Home Depot, I looked at the different Zep products. For "step 3", there where (2) options. (1) high gloss with 19%solids ($25.00 per gallon) and an industrial with 20% solids ($17.00 per gallon). I bought the $17.00 gallon due to higher solids an price.
When I got home I did a test section, (6) coats and it looks "ok"? Did I make a mistake buying the cheaper gallon, or do I need more coats?
036.6turbo is offline   Reply With Quote
Old 08-03-2014, 07:16 AM   #712
Name:	ImageUploadedByFiberglass RV1407071796.125205.jpg
Old 08-03-2014, 07:52 AM   #713
Can't say that I have ever seen two different versions of ZEP "Wet Look", but I would guess that a higher solids concentrate should cost more if it is, indeed the same stuff, only better?
That said, the positive reports I have been reading about the ZEP product have been applications on light colored molded fiberglass surfaces which is somewhat different in surface finish and texture than the black sheet fiberglass your 5er is constructed of, and that may also make a difference. I also know that the flat surface fiberglass sheeting (especially darker colors?) is more prone to weathering damage, and something we may see after many, many rears, called "shredding" where tiny shreds of fibers start appearing on the surface.
To answer your question, on the three molder fiberglass RV's I have done, 4 coats always did the job.
As most modern RV's now use that same type of sheeting, you might check on some of the conventional built sites as they will have more experience with restoration of that specific material than most of us hereabouts.
Old 08-03-2014, 10:14 PM   #714
North Dakota
Dudley, it looks great. I see you removed the AC like you said too. Glad to see it went to a good home. Did you get the Fantastic Fan problem solved too? Happy camping!
poliglow
check out Emmitt G. Classified Archives 1 03-09-2010 01:33 PM
Check this out Kevin K General Chat 4 06-13-2009 10:30 AM
Check this out Kevin K General Chat 5 02-02-2009 10:07 AM
Hey Web Guy Check this out ! Glen G General Chat 12 02-20-2008 01:06 PM
