Check this out NOT Poliglow...Time will tell.. - Page 59 - Fiberglass RV
Old 09-10-2016, 11:56 PM   #813
Thee Jimbo's Avatar
I guess I'm unclear on what you mean by giving it a wipe and "it came right up". Not sure what that means. Sorry
Thee Jimbo is offline   Reply With Quote
Old 09-11-2016, 07:57 PM   #814
Roy in TO's Avatar
By single wipe, I lightly cleaned the area (might have been with Awsome), cleaned that off with a wet rag, then put a little ZEP on the cloth and gave it a single wipe over the area. That is one light coat with no sealer.
This is what it looks like a year later. You can see the outline of the wax and the difference in colour on the stripe. The "Trillium4500" was screened on and really faded. The single wipe brought the colours right out.
I didn't do a lot because I have to strip the stripes off. I also have to prep the entire trailer for waxing. I have new decal stripes to replace the cracked ones with. I also bought replacement "Trillium4500" decals, but if the Zep is going to bring out the colour like this, I see no need to replace them.
Old 09-11-2016, 08:10 PM   #815
Thee Jimbo's Avatar
Wow I see what you mean. I put new stickers on my scamp and am waxing it sll. Expecting bye was to keep the stickers safe and sound too
Old 09-11-2016, 08:20 PM   #816
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
Attachment 99669
Be very careful removing that cracked stripe because it is a real chore, I used a hair dryer to heat it up but that is dangerous also because you don't want to over heat the gel-coat.. Someone else might have a easier way to remove it but that was my best way to do it..... just don't get in a hurry and take your time..... Once removed I painted the new stripe on.....
Randy Bishop is offline   Reply With Quote
Old 09-11-2016, 09:22 PM   #817
Dudley's Avatar
Trailer: 1998 Casita 17 SD
To remove the blue trim I would get a 3M Stripe Off Wheel. My neighbor used one and it worked great. BTW you may have some ghosting and color transfer on the gel coat behind the stripes (i did after removing the Casita logo on my 1998 casita)
Old 09-11-2016, 11:56 PM   #818
Trailer: Burro 1983 13'
Wisconsin
To me I think the floor polish looks better.
I am still afraid to use these and have gotten great
results with a good marine high grade wax and a lot
of elbow grease! Seeing your great shine it is very tempting
to try.
Burro Bill is offline   Reply With Quote
Old 09-12-2016, 01:10 AM   #819
Borrego Dave's Avatar
Trailer: Casita SD17 2006
to try.
BB, I've used paste wax and electric buffers on other Rv's but the Zep is so much easier/faster and to me, keeps the shine longer. I can strip and put 5 coats of Zep on my SD 17 in 3-4 hours...with a beer break or two . Bottom line, any kind of wax you are comfortable using is better than nothing at all.
Borrego Dave is online now   Reply With Quote
Old 09-12-2016, 09:37 AM   #820
Wisconsin
Dave,
There is no guestion the shine is impressive with the floor polish.
I still like the UV protection I also get from the marine wax and
removing the polish to redo the camper sounds like work!
Something I try hard to avoid!
Bill
Old 09-12-2016, 10:58 AM   #821
North Dakota
Dave,
Bill
If you want the UV protection just use Poliglow. It's suppose to have that in it. Even though it's more expensive a kit comes with a cleaner and tools to do the job. I have tried both with equal results but I liked the tools the Poliglow came with and used them to apply the Red Max (Zep Wet Look) product also.
Gene Masse is offline   Reply With Quote
Old 09-13-2016, 12:34 AM   #822
Thee Jimbo's Avatar
So I've done two rounds of RMP. I did the bottom of my scamp yesterday in warm weather. 7 coats. Great shine
Did the top today. Cooler weather. More of a satin finish. Could the temperature affect this ? Or the time between coats. Maybe not fully dry between coats ?
Has anyone else had this happen ? Is there a way to remedy this other than stripping it all off ?
Old 09-13-2016, 05:46 AM   #823
Trailer: 1999 Casita 17' SD
Ohio
Most likely from not being dry.
Try another thin coat.
Old 09-13-2016, 05:59 PM   #824
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Thin coats seem to be better than thick. I try to put the last two on in long sweeps with a lighter touch.
mmeyer is offline   Reply With Quote
Old 09-13-2016, 06:34 PM   #825
Trailer: 1976 Trillium 1300 pulled by a 2015 Jeep Rubicon Unlimited
ZEP after 6 coats
I decided to go for it and rubbed the entire trailer down with Bar Keepers Friend, then applied 6 coats of ZEP floor finish. Amazing, and very easy. Took 39 years off of our 40 year old trillium. :-)
LionelAucoin is offline   Reply With Quote
Old 09-15-2016, 08:29 AM   #826
Trailer: 2013 Escape 19
FWIW, I just removed all the decals on my 1996 Casita. They were cracked and faded. I started with a hair dryer, gave up on that approach pretty quickly. I then went to the carefully peel up a corner with a finger nail, grab the small flap with a needle nose pliers, and then carefully pull them off. It worked well for me.
The reason I used needle nose pliers is the flap needed to grab with my fingers would be 5X the size needed to grab with the pliers. Once I had a decent sized flap, I then pulled it off with my fingers.
Now I have to deal with the shiny white gel coat under the decals versus the faded gel coat everywhere else. Even in its current state, the trailer looks 100% better to me.
poliglow
check out Emmitt G. Classified Archives 1 03-09-2010 02:33 PM
Check this out Kevin K General Chat 4 06-13-2009 11:30 AM
Check this out Kevin K General Chat 5 02-02-2009 11:07 AM
Hey Web Guy Check this out ! Glen G General Chat 12 02-20-2008 02:06 PM
» Trailer Showcase
Alice
Tim D.
Janet H
» Virginia Campgrounds
