Cleaned up Scamp hinges - Fiberglass RV
Old 08-20-2017, 07:53 PM   #1
TN
We bought a 16ft Scamp about six weeks ago and set about cleaning it up. I wanted to clean up the hinges and the door hold so I bought a few parts and then pulled the hinges off and started cleaning them up.
Now I have them installed along with stainless steel acorn nuts and hinge bolts.
I also installed a new set of door holds while I was at it.
Eric Frye is offline   Reply With Quote
Old 08-20-2017, 08:04 PM   #2
Trailer: 1992 Scamp 13'
Those hinges look amazing! What product did you clean them with?
lisantica is offline   Reply With Quote
Old 08-21-2017, 04:46 AM   #3
TN
I used sand paper starting with 40 grit and worked up to wet sanding with 1200 then polished with rouge. It took a couple of hours while watching tv.
Old 08-21-2017, 05:55 AM   #4
Al and Cindy K's Avatar
Trailer: 2002 16 ft Scamp
nice job...............and congrats on the Scamp,
Al and Cindy K is offline   Reply With Quote
Old 08-21-2017, 06:21 PM   #5
To take the handle off do you need to remove the door lining? Also, which parts did you purchase and where? My husband's 2000 Scamp just came to live at our house and we're doing little things to it; the door hardware would be really nice to clean up. Thanks!
emersunrose is offline   Reply With Quote
Old 08-21-2017, 07:04 PM   #6
TN
I didn't remove the door handle just the hinges and the catch that holds the door open. I don't think you would need to remove the lining to take of the door handle. I go the hinge repair kit from CampingTreasures.com and the acorn nuts from Lowes.
Old 08-21-2017, 07:11 PM   #7
THANK YOU!
Old 08-22-2017, 11:38 PM   #8
Jan Dyke's Avatar
Trailer: boler
Christine, hinges unbolt from the inside, you should see the bolt heads just inside the door frame, Remove outer nuts and washers first, same thing on the door. Nice job Eric, I did the same but never polished mine, but after seeing yours I think I will
Jan
Jan Dyke is offline   Reply With Quote
Old 08-23-2017, 02:29 AM   #9
Trailer: Trails West
So much shine I am blinded
Old 09-01-2017, 08:06 AM   #10
Name: Steve in NY
I bought new hinges from Scamp last year and the acorn nuts are already rusted. I am going to replace the nuts with SS. I'll use your method to clean the hinges. Thanks.
Steve in NY is offline   Reply With Quote
Window Trim cleaned up Kevin K Problem Solving | Owners Helping Owners 2 04-30-2016 11:29 AM
Replacing 1974 boler hinges with new scamp hinges ArneB Modifications, Alterations and Updates 2 08-10-2015 12:39 PM
