Cleaning up an old Boler - Page 3 - Fiberglass RV
Old 02-22-2016, 10:43 PM   #29
Trailer: 1975 Boler
Quebec
I know I'm reviving this thread. You'll appreciate the heart warming story...
My spare tire almost pulled out my back wall as much as this one. Since I'll be repainting, I'm considering the bumper mount. I would fill in those holes.
My guess is that my backing plate is no bigger than 2" x 5". It apparently didn't do the job.
Any opinion on this?
Also, I need to replace the heater vent and the opper fridge vent. Any suggestions as to where to find that?
Thanks!
Uncle Cereal is offline   Reply With Quote
Old 02-24-2016, 01:29 PM   #30
Keaner's Avatar
Trailer: 1973 13' Boler
Do the heater and fridge work? I tossed mine and glassed over the holes.
Keaner is offline   Reply With Quote
Old 02-24-2016, 02:13 PM   #31
Trailer: 1975 Boler
Quebec
Bought a small electrical fridge and, as far as I know, the heater works.
Old 03-05-2016, 02:17 PM   #32
Wow, old thread revival is right!
Uncle Cereal, what we finally did for the spare tire carrier was added a backing plate inside the trailer. If memory serves correct, it was a pc of 1/2" plywood about 16" wide by 4" high. And we added the backer bolts to prevent the tire from being sucked in too far.
Otherwise, that was it. Good luck with your project.
Thanks!
justchillinout is offline   Reply With Quote
Old 03-05-2016, 02:56 PM   #33
Trailer: 1975 Boler
Quebec
Just got back from the garage... My bumper's not in good shape enough to hold up the spare so I'll have to put it back up on the wall.
What's a backer bolt?
Thanks!
Old 03-06-2016, 12:43 PM   #34
Regarding the backer bolts or stop nuts as Randy Bishop noted in an earlier post.
There is a set of bolts that hold the threaded rod to the trailer and are tight to the outside of the trailer.
Then the stop nuts, which are spaced between the trailer and the spare tire.
Then nuts to hold the rim to the threaded rods.
Hopefully that makes sense. The stop nuts keep the tire AWAY from the trailer enough that the bolts don't pull through like they did on our trailer.
Using my previous pic as an example:
Hopefully this helps.
Originally Posted by Randy Bishop View Post
Looks like someone didn't put stop nuts on the spare holder ..what it needed was a second set of nuts on the bolts to serve as a stop to keep the bolts from pulling through if someone tighten the nuts to tight drawing the bolts through the fiberglass. I can't really tell from the photo's how bad it is but you might be able to put them on now and it be OK..Also a spare rack mounted on the bumper as you mention would work..As far as trying to repair the damage I would probably try to seal the cracks and leave it along, because anything else would require a paint job to cover the repairs.......Theres a product that some people on here has used called Captain Tolleys Creeping Crack Repair.... I personally have not used it but maybe someone else can chime in that has used it and tell how it may have worked for them.....It should help on any stress cracks you may have also..If after a good scrubbing there's still a faded look to it you might try sanding it down with 400 grit sandpaper.One of my trilliums was faded pretty bad and that worked great for me I used a electric palm sander and went over the entire camper turned out great, just make sure the gelcoat doesn't have any thin places in it where you might sand down through it and expose the fiberglass underneath..The gelcoat on most of these is fairly thick enough to take a little sanding just be careful..How big are those tail lights, I've got a set of round LED's I bought once to put on a Burro I once owned but they didn't work out.. If I can find them and if they will fit they are yours since your doing this as a favor for the folks...I'll dig around tomorrow and see if I can locate them and see what size they are.... The best that I can remember they were around 5" or 6" but can't remember for sure....GOOD LUCK WITH THE CAMPER RANDY...
Old 03-06-2016, 01:02 PM   #35
Trailer: 1975 Boler
Quebec
I get it! Thanks!
Someone had put the nuts INSIDE mine! Theft-proof for sure but a little rough on the fiberglass wall... Sounds good, I'll be adding a few nuts!
Old 04-12-2016, 09:52 AM   #36
Trailer: Scamp 19'
I understand the scotch-brite scouring pads and the BarKeepers Friend as I am in the food industry! What Zep product did you use and what were the steps of the process using Zep? I have a Scamp 19' and the gel-coat is chalky and needs attention. You did a great job, if I could get close to the same results I would be a happy camper.
Myderby is offline   Reply With Quote
Old 04-12-2016, 01:16 PM   #37
Dan Meyer's Avatar
Elbow grease plus what magic product restored the shine?
Thanks in advance!
--Dan Meyer
Old 04-12-2016, 02:12 PM   #38
Keaner's Avatar
Not sure about those backer bolts. Is that a factory spec or an addition? I think with the slop of the tire bouncing around you're going to get a lot of damage to the paint and elongated holes in the shell.
I believe it should be tight against the shell with the proper backing plate on the inside of the unit.
Old 04-12-2016, 03:55 PM   #39
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Can't see that hanging the spare off the fiberglass is a good idea no matter how you do it !!! If the bumper is in that bad a shape maybe it needs attention !!!
Bob in Mb is offline   Reply With Quote
Old 04-12-2016, 05:37 PM   #40
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Myderby and Dan Meyer,
There is a lengthy thread on how to apply Zep and similar products to FGRVs. I applied Zep commercial wet look floor polish to my Trillium last fall. I applied with a micro fiber cloth soaked with Zep and wrung out. Applied five coats, waiting 1/2 hour between coats. Don't apply in direct sun.
-John
Old 04-12-2016, 06:19 PM   #41
If the gel coat is chalky pick yourself up a polisher with a wool bonnet and a bottle of 3M Marine Restore and Wax. You will not be sorry
Old 04-12-2016, 06:53 PM   #42
Keaner's Avatar
I should add mine sits on the bumper as well as tight to the rear wall.
Given the issues with your bumper, it is worth it to get underneath and inspect the frame.
boler
Cleaning Side Vents Boler jeanpierre Problem Solving | Owners Helping Owners 11 04-02-2011 02:18 PM
cleaning crm112 Problem Solving | Owners Helping Owners 7 03-14-2011 04:49 AM
Cleaning fiberglass Daryl R Care and Feeding of Molded Fiberglass Trailers 9 05-16-2010 11:52 AM
Self-cleaning Dogs Pete Dumbleton General Chat 6 05-30-2008 11:25 PM
Cleaning Stove Legacy Posts Problem Solving | Owners Helping Owners 2 08-05-2003 07:42 PM
