cleaning water tanks - Page 2 - Fiberglass RV
Old 03-29-2009, 11:39 PM   #15
Roger C H's Avatar
Talking
1.25 ounce [US, liquid] = 2.5 Tablespoon [US]<a href="http://www.onlineconversion.com/cooking_volume.htm" target="_blank">
</a>
1.25 ounce [US, liquid] = 7.499 999 999 8 Teaspoon [US]
Conversions from:
Someone said using a shot glass. Just how much vodka would it take to disenfect. And then you wouldn't have to drain it, just drink it. LOL
Old 03-30-2009, 12:11 AM   #16
Roger C H's Avatar
Talking
From Wikipedia:
http://en.wikipedia.org/wiki/Sanitize
Home disinfectants
By far the most cost-effective home disinfectant is the commonly used chlorine bleach (a 5% solution of Sodium hypochlorite) which is effective against most common pathogens, including such difficult organisms tuberculosis (mycobacterium tuberculosis), hepatitis B and C, fungi, and antibiotic-resistant strains of staphylococcus and enterococcus. It even has some disinfectant action against parasitic organisms <sup>[5]</sup>. Positives are that it kills the widest range of pathogens of any inexpensive disinfectant; it is extremely powerful against viruses and bacteria at room temperature; it is commonly available and inexpensive; and it breaks down quickly into harmless components (primarily table salt and oxygen). Negatives are that it is caustic to the skin, lungs, and eyes (especially at higher concentrations); like many common disinfectants, it degrades in the presence of organic substances; it has a strong odor; it is not effective against giardia lamblia and cryptosporidium; and extreme caution must be taken not to combine it with ammonia or any acid (such as vinegar) as this can cause noxious gases to be formed. The best practice is not to add anything to household bleach except water. Dilute bleach can be tolerated on the skin for a period of time by most persons, as witnessed by the long exposure to extremely dilute "chlorine" (actually sodium or calcium hypochlorite) many children get in swimming pools.
To use chlorine bleach effectively, the surface or item to be disinfected must be clean. In the bathroom or when cleaning after pets, special caution must be taken to wipe up urine first, before applying chlorine, to avoid reaction with the ammonia in urine, causing toxic gas by-products. A 1 to 20 solution in water is effective simply by being wiped on and left to dry. The user should wear rubber gloves and, in tight airless spaces, goggles. If parasitic organisms are suspected, it should be applied at 1 to 1 concentration, or even undiluted; extreme caution must be taken to avoid contact with eyes and mucous membranes. Protective goggles and good ventilation are mandatory when applying concentrated bleach.
Commercial bleach tends to lose strength over time, whenever the container is opened. Old containers of partially used bleach may no longer have the labeled concentration.
Where one does not want to risk the corrosive effects of bleach, alcohol-based disinfectants are reasonably inexpensive and quite safe. The great drawback to them is their rapid evaporation; sometimes effective disinfection can be obtained only by immersing an object in the alcohol.
Notice the bolded portion. Someone in this thread said to use vinegar after the bleach. It also says not to combine anything with the bleach. To avoid problems, it may be wise to do a rinse after the bleach before applying vinegar (acid) or baking soda (base). The gas that can form is chlorine which is a bad actor. Of course if you use the extremely diluted amounts, that should also prevent any problem.
Cleaning out water tank? barryra Care and Feeding of Molded Fiberglass Trailers 44 03-25-2015 10:55 AM
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
Towing a 13' Boler with full water tanks Chris de Haan Towing, Hitching, Axles and Running Gear 6 06-18-2009 08:51 PM
Water Tanks Jim Stacey Plumbing | Systems and Fixtures 9 09-03-2007 10:01 AM
Tote Tanks Legacy Posts Plumbing | Systems and Fixtures 11 03-14-2003 09:38 AM
