cleaning water tanks - Fiberglass RV
Old 03-29-2009, 08:36 AM   #1
Dale C's Avatar
Trailer: 1976 13 ft Scamp
When I pump water from the tank of my new to me 1976 Scamp what comes out doesn't look that great. What procedure is recommended for cleansing the tank.
I appreciate the great advice given here.
Dale
Dale C is offline   Reply With Quote
Old 03-29-2009, 10:07 AM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Dale THIS link may help you out.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 03-29-2009, 10:18 AM   #3
Dale C's Avatar
Thanks Jim. That was just what I was looking for!
Dale
Old 03-29-2009, 10:24 AM   #4
I can't recommend bleach. I did that based on the link Dale added. I added bleach to a half tank, drove around to swish it, then drained and rinsed the tank. We are into our fourth day of a five day trip and the water STILL tastes like bleach. I may have used too much but I ain't gonna do it again.
We will try the baking soda approach next year unless a better idea is proposed.
BTW, we only put antifreeze in the drains. We emptied the hot water tank then blew out the lines. We had a fairly hard winter and came out OK.
Dave
Dave Fish is online now   Reply With Quote
Old 03-29-2009, 10:27 AM   #5
Dave
I thought the idea was to use baking soda AFTER the bleach to neutralize the chlorine and not to just use one or the other?
Old 03-29-2009, 11:19 AM   #6
Leehman's Avatar
While living aboard our boat with fiberglass water tanks we found 1/4 teaspoon of bleach per fifty gallons of water worked well. Also used 1-2 teaspoon of vanilla. After drinking that water for several months when you sweat you will smell like a new cake.
Leehman is offline   Reply With Quote
Old 03-29-2009, 01:19 PM   #7
Dave, I have used bleach many, many times. I only ever rinse once, and that just about clears it up. If you are drinking the water and you still notice some taste, you can fill a jug and let it sit for a bit.
I know of a few folks who do a soda rinse after the water rinse, and they have all claimed that this clears it up completely.
2017 Escape 5.0 TA
Old 03-29-2009, 01:46 PM   #8
Pete Dumbleton's Avatar
Despite the fact that it comes in gallon jugs, only a tiny bit of bleach is required, and the baking soda IS for the cleanup of the bleach, not the cleanup of the tank.
Using too much bleach will cause the tank to taste like bleach for many refills, just as Dave found, if the baking soda isn't used afterwards!
Old 03-29-2009, 05:41 PM   #9
Thanks everyone. Tooooo much bleach, no bakng soda. I will do t different next year.
Dave
Old 03-29-2009, 06:17 PM   #10
ronsmith100's Avatar
I am not a trailer guru but let me ask this question:
If you put lots of chlorine in your water tank every time you fill up is there any way goop can grow or anything?
I never drink that water so.....
ronsmith100 is offline   Reply With Quote
Old 03-29-2009, 06:31 PM   #11
Roy in TO's Avatar
FYI from Oregon Health Services
http://www.oregon.gov/DHS/ph/dwp/docs/haulguide.pdf
Old 03-29-2009, 06:47 PM   #12
"2 quarts of chlorine bleach for every 500 gallons of water used to fill the tank."
Well Pete did say a tiny bit was all that was needed. At this rate, I'd think a gallon of bleach would last my lifetime.
Old 03-29-2009, 08:55 PM   #13
That works out to about 1.28 oz bleach for a full ten-gallon tank -- Or less than eight teaspoons...
Old 03-29-2009, 09:29 PM   #14
Roy in TO's Avatar
I seem to recall some shot glasses that had a line at the 1.25 OZ mark. That would be pretty darn close.
Cleaning out water tank? barryra Care and Feeding of Molded Fiberglass Trailers 44 03-25-2015 10:55 AM
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
Towing a 13' Boler with full water tanks Chris de Haan Towing, Hitching, Axles and Running Gear 6 06-18-2009 08:51 PM
Water Tanks Jim Stacey Plumbing | Systems and Fixtures 9 09-03-2007 10:01 AM
Tote Tanks Legacy Posts Plumbing | Systems and Fixtures 11 03-14-2003 09:38 AM
