Compact, what else? - Fiberglass RV
Old 04-02-2009, 10:06 PM   #1
Trailer: Hunter Compact ll
Angry
Hi folks.......I have a 73 compact ll, and have been taking care of some issues in the last year.......ditched the furnace, and had a 20,000 btu forced air replacement installed. That cured the cold issue. Took out the hot water heater before it torched me/and/or the camper with it. Im thinking about installing some sort of on demand unit in its place. And had the brake/taillight/turn signal wiring replaced from stem to stern, it was rotten. Next is the axle. I was towing it this summer, and I was really concerned about the rocking motion, from side to side, when I inadvertently turned the wheel. It was flat out dangerous. So I took it home, jacked it up, and removed the offending axle before I was tempted to take it out again. Ive priced new axles, they are not too bad, really, less than 300.00. The old one was a flimsy thing, and it was a drop axle, about 4". My plan is to re-install a straight axle with brake flanges. It will lift the whole thing 4 in. Then I can put some real tires and wheels on it, to match the 4x4 that will be pulling it. Maybe some custom flairs for the fender wells. Anybody have input on this????? Thanks, Mitch
Mitch Johnson is offline   Reply With Quote
Old 04-02-2009, 10:28 PM   #2
Larry&Carrie's Avatar
Trailer: 13 ft Scamp 1983 and 1972 Compact Jr (project)
Send a message via MSN to Larry&Carrie
Talking
Mitch- I rebuilt a Compact JR this last summer and one of the things I did was build a straight (non-dropped) axle for it. I was unhappy about how low it was.... (see before and after pictures) However, I do have to admit that it still sways (bobble at 70 mph) so have to stay at 65 or lower. I think the solution would be to put shocks on it as I think the sway comes from the shackles on the rear of the springs-- no solution that I know of to cure that and shocks may be the answer. Larry
Larry&Carrie is offline   Reply With Quote
Old 04-03-2009, 01:00 AM   #3
Raya's Avatar
Could a torsion axle be fitted to a Compact instead of the leaf-spring axle?
And would that help to reduce the bobble? (In other words, is that why the Boler doesn't bobble?)
Raya
Old 04-03-2009, 10:35 AM   #4
Talking
Raya
A torsion axle in my mind is a lot more stable (yeah that's prob why your Boler - and my Scamp doesn't bobble- up to 75 mph+ ). But, to convert to a torsion axle on a Compact would take some creative frame fabbing, and cost a lot more than just adding shocks.... A simple straight non-drop axle should be obtainable in the $150 range, as where a Dexter is about twice that much....
Larry
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Our new Compact Jr. Ricky 4 Care and Feeding of Molded Fiberglass Trailers 3 08-03-2009 07:29 AM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
Compact Jr Jayson Jones General Chat 0 01-01-1970 12:00 AM
