I've been offered a 73 trillium for free. I know next to nothing about trailers, but love the looks of this little guy. Is it possible to tow it with either a Honda Accord or Toyota Camry (both are 4 cylinders)?
If I were you, I'd check the official towing capacity in the manual for your specific vehicle (some older Camry's had a 2000 lbs towing capacity, most newer ones: 1000 lbs; this could be higher if the trailer has
brakes; probably much lower for 4-cyl), determine how much your Trillium's real
weight would be once fully loaded (typically between 1400 and 1900 lbs), add a safety margin, and base your decision on those numbers rather than opinions. But then again, this is also an... opinion.
