Contact information - Fiberglass RV
Old 07-05-2008, 04:36 PM   #1
Trailer: Travelaire 19 ft 5th Wheel
I am interrested in the Quantum5th wheel can someone give me the manufacturers contact or a dealer, thank you, Ray
Ray John S is offline   Reply With Quote
Old 07-05-2008, 04:59 PM   #2
Ray, if you're talking about the molded fiberglass Quantum 5th wheel, it's no longer manufactured, and hasn't been for years. In all the time I've been a member of this forum, I've only seen 3-4 for sale, and often the trailer(s) are sold between members.
Old 07-06-2008, 09:50 AM   #3
Donna, thank you for letting me know. I have spent considerable time doing web searches to no avail. Too bad, we thought we had found just what we wanted, small, dual axle, large windows including a front window, double sink, etc. I will watch just-in-case a used one surfaces, thanks again, Ray
Old 07-06-2008, 11:27 AM   #4
Keep an eye out for a double-axle BigFoot 5th wheel too. I think you'll find most of the items you're looking for in a trailer can be found in the BigFoot.
Unfortunately, the BigFoot 5th wheel is no longer being manufactured either, but at least you'll see more availability than the Quantum.
Old 07-06-2008, 05:36 PM   #5
Alf S.'s Avatar
Hi: Ray...Sorry our Escape 5.0 191/2' 5th. wheel doesn't measure up. We just returned from Ont. Bolerama 2008 and received rave reviews from most all 100+ Fiberglass Owners at the rally. Check over @ Escape trailers in Chiliwack B.C. as they are in your neck o' the woods.
Old 07-07-2008, 08:23 PM   #6
Trailer: none
Check Vantastic Vans in Albuquerque N.Mex. They have one also a Casita.
http://vantasticvans.com/used-rv-sales-new-mexico.aspx
I hope it works.
Jayfor is offline   Reply With Quote
Old 07-07-2008, 08:34 PM   #7
Trailer: Fiber Stream
Talking
[b]I hope it works.
1980 CONTEMPO QUANTUM
2003 CASITA LIBERTY
Old 07-07-2008, 10:34 PM   #8
Thank you ! I will check it out, Ray
Old 07-12-2008, 08:47 AM   #9
Hi: Ray...Sorry our Escape 5.0 191/2' 5th. wheel doesn't measure up. We just returned from Ont. Bolerama 2008 and received rave reviews from most all 100+ Fiberglass Owners at the rally. Check over -Do Not Post Email Addresses- Escape trailers in Chiliwack B.C. as they are in your neck o' the woods.
They certainly have a good reputation, and are only 45 km from us. However, I only wish I was in a position to afford new, I am thinking 5 or 6 thousand. The other issue is that I have a single axle now and 3 years ago I had a blow-out on it (busy hiway, now where to get of, had to change it (drivers side) with semi-trailors etc. nearly blowing me over) and it has sort of tainted my enjoyment on the road, so really want a double axle, Ray
Old 07-12-2008, 09:09 AM   #10
I can understand your comprehension. But what would you do under the circumstance, if you weren't towing a trailer and had a blow out on the tug??? I doubt you drive a vehicle that's got two wheels all the way around. I only mention it, because you're focusing on the trailer single-axle, but so does the tug. You can pull all the double-axle trailers around, but it doesn't change the tug single-axle problem. A blow out or flat tire, the position is the same.
Trailorboat Contact ron edwards General Chat 2 12-18-2009 08:29 AM
Help - Unable To Contact Casita Lance McCasland General Chat 3 07-06-2006 12:24 PM
Electrical contact cleaner Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 03-25-2003 03:09 PM
