Coupler Question - Fiberglass RV
Old 07-12-2010, 08:26 PM   #1
Lainey's Avatar
Trailer: 1989 Bigfoot 17 ft and 1989 Li'l Bigfoot 13 ft
Just wondering if anyone knows if there is a way to lock this style of coupler while the tailer is hitched? It is the coupler for the L'il foot. On my Bigfoot I use a locking hitch pin, but that won't work here. I know I can get one of those ball type locks to lock it while unhitched, but it would be nice to be able to lock the trailer to the TV so that I don't have to worry about the trailer migrating while I'm away from the rig if parked somewhere... Not sure, but did this coupler have a key at one time? The original owner never provided a key and I've never seen another coupler this style.
Thanks
Lainey is offline   Reply With Quote
Old 07-12-2010, 08:39 PM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Some locks here
http://www.google.com/imgres?imgurl=http:/...BFcH58Aan24GpBg
Old 07-12-2010, 08:40 PM   #3
Trailer: Fiber Stream
Talking
Attachment 29433
It sure looks like this coupler has a built-in lock, and you're just missing the key.
Old 07-13-2010, 08:50 AM   #4
Trailer: Boler 1300 1980
Hi Lainey.
I also have an uncommon coupler style, difficult to lock also. While hitched to the tv I use a bicycle cable lock, trough the safety chain attachment on the T.V. and inside the A-frame on the trailer. Hummm... hard to see from the picture but is your trailer a straith pole ?
GuyBou
Guy, Boulianne is offline   Reply With Quote
Old 07-14-2010, 05:56 AM   #5
DonDeutsch's Avatar
I am thinking itis time for a new coupler but a locksmith should be able to fix the lock and/or provide you a key.
DonDeutsch is offline   Reply With Quote
Old 07-14-2010, 12:03 PM   #6
Lainey's Avatar
Frederick: I am probably missing more than just a key!
So, after some research it turns out that there was a brass barrel lock with a key for this Al-Ko Kober coupler.
I have even found the part number for this (203216)... just can't find anyone in North America that will sell me one! I'll bet Lex has seen these before!
When the brass piece was left in the coupler, the coupler is disabled. Insert key into brass piece to remove. Seems pretty simple.
Old 07-14-2010, 01:55 PM   #7
Trailer: 13 ft Scamp Deluxe 2007 and 40' Allegro Bus
Iowa
Send a message via AIM to RSchleder Send a message via Yahoo to RSchleder
A new coupler is very inexpensive and pretty easy to install assuming you have ( or know someone) with some basic mechanical skills and a few tools.
RSchleder is offline   Reply With Quote
Old 07-14-2010, 07:02 PM   #8
Doug Arthurs's Avatar
Replace it. Couplers wear out. My neighbor had his trailer come uncoupled. As I was welding the new one on he says "I don't understand what happened I have been towing that trailer for 30 years and never had a problem before." LOL I could lock it to the ball and then lift it right off. Totally worn out.
Doug Arthurs is offline   Reply With Quote
Old 07-20-2010, 08:05 AM   #9
Yeah, and I see the one on your trailer is bolted on Lainey. I think the Reece brand is available at Walmart for $25-$35 for a 3500 lb. Pretty cheap insurance.
What's a good coupler lock for a scamp 13 bcomnes Care and Feeding of Molded Fiberglass Trailers 8 01-26-2010 09:37 PM
coupler height cyndi H Towing, Hitching, Axles and Running Gear 18 05-04-2008 05:52 AM
Boler Hitch Coupler A. Robert Reed Problem Solving | Owners Helping Owners 2 08-14-2007 05:46 PM
Coupler Concern Chris73 Towing, Hitching, Axles and Running Gear 7 07-30-2006 03:26 PM
coupler height cyndi H Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
