D rated 14 inch TRAILER TIRES? - Fiberglass RV
Old 11-23-2007, 01:59 PM   #1
Trailer: 17 ft Casita
Looking for a source for some D rated 205/75 14 tires. I don't want Goodyears and the only orthers I have found are KHUMO 857's which are on back order and unavailable anytime soon from TIRE-RACK.
BOB & JACKIE
Bob Radenbaugh is offline   Reply With Quote
Old 11-23-2007, 02:26 PM   #2
I searched for new tires last year and found the Duro brand, available through America's Tire. However, they are C range, so they may not fit the bill. Max. load 1760 lbs per tire.
The original tires on the Burro were 13 inch Duros, and we never had a problem with them, but the 14 inch wheels and tires brought us a comfortable load margin, so I'm happy. I get the impression they are a cut above the usual suspects, quality-wise.
Old 11-23-2007, 02:34 PM   #3
Brian B-P's Avatar
The Continental Vanco 8 is a suitable commercial truck and trailer (not ST) tire which is made in Load Range D, in similar sizes such as 205/80R14. That particular size is almost an inch taller than a 205/75-14 and possibly closer to the original size on trailers such as my B1700, which came with an F78-14 tire in 1979.
I don't know how readily available the Vanco 8 is.
All ST tires in the same size and load range will have the same load capacity, so I assume that Bob's intention is to find a tire with a higher load capacity than that of an ST205/75-14 LR-C.
Old 12-21-2007, 06:52 AM   #4
andy s's Avatar
Trailer: 2008 Casita 17 ft Sirit Deluxe
I got my 195/14 Kuhmos today. They are 1/2 inch narrower than the Kuhmo 205.
However they are the same width as the goodyear 205. They carry a load rating of
just over 2000 lbs. They are a 1/4 inch taller than the 205 Marathon.
Tire Rack has them in stock and Discount Tire got them for me in 3 days. Discount
matched Tire Racks price of $73
andy s is offline   Reply With Quote
Old 12-21-2007, 09:14 AM   #5
HaroldB's Avatar
Trailer: Casita Spirit Deluxe 2005
I don't know how readily available the Vanco 8 is. . . . . .
Tire Rack shows the Vanco™ 8 195/R14 (2094 weight limit) in stock @ $86.
Harold
OUR PERSONALIZED CASITA
HaroldB is offline   Reply With Quote
tires
14 inch tires on S13? adimiro Care and Feeding of Molded Fiberglass Trailers 13 11-04-2011 07:51 AM
Using a WDH rated higher than required kevin61 Towing, Hitching, Axles and Running Gear 9 05-02-2010 06:24 AM
Temperature (Rated G) Legacy Posts Jokes, Stories & Tall Tales 8 01-28-2003 03:45 PM
» Trailer Showcase
Roly Poly
Lindl
Rocky
ljsilver
