Davis 1458 Air-Dryr 1000. Good? Alternatives? - Fiberglass RV
Old 09-20-2017, 03:30 PM   #1
Nik
Nik's Avatar
Trailer: BigFoot
Red face Davis 1458 Air-Dryr 1000. Good? Alternatives?
I'll be storing my 17' Bigfoot soon. This year it will live outdoors in the rainy Northwest. The people I bought it from had it covered with a soft, torn-up 'bag' cover followed by a waterproof tarp. I figure I'll do the same.
I'd like to keep the moisture down inside. I found the Davis Air-Dryr 1000 at about $55. Apparently it works. A regular heater I imagine would cause condensation, making things worse. Any experiences with this David unit?
So, with the Air-dryr, does one keep a window ajar? if so, why? And any alternative ideas? I plan to remove all the cushions for inside storage. Next year she'll have a garage. But still I will want to keep some kind of drying unit inside!
ps. She's been through the first rainstorm yesterday. No leaks at all. She'll be well covered. It's just the ambient air I'm worried about here in Oregon's westside.
Nik is offline   Reply With Quote
Old 09-21-2017, 10:27 AM   #2
Ohio
I learned a trick from the boaters that had their boats sealed in plastic for the season. Place a 5-gallon bucket of charcoal briquettes inside to absorb moisture.
cmartin748 is offline   Reply With Quote
Old 09-21-2017, 11:14 AM   #3
Nik
Nik's Avatar
Trailer: BigFoot
That charcoal idea sounds great.
Old 09-21-2017, 11:32 AM   #4
A friend gave me his Davis that he had been using in his tug. I came to the conclusion that it was no better than a 60 watt bulb. It heats the air slightly, so the air can contain more moisture. The moisture itself doesn't go anywhere, isn't collected to be removed from the space. I tossed it out.
Replaced it with two Dri-Z-Air containers with desiccant that I bought in a half/gallon jug ( cheaper that way ). Moisture is removed from the air and collected in the container which is emptied every two or three weeks. I get about a cup of liquid in each Dri-Z-Air.
Old 09-21-2017, 11:42 AM   #5
TomK's Avatar
I used Damp Rid when we stored our Scamp 13 outdoors under a Calmark cover. I actually used the smaller 10.5 oz. size, but your trailer is bigger and your environment is much damper. It worked very well. No mildew smells at all. I was advised to put the bucket in a pan in case it overflowed, but that never happened.
DampRid 64 oz. Fragrance Free High Capacity Moisture Absorber-FG50T - The Home Depot
Tom
Old 09-21-2017, 12:40 PM   #6
I use Dri-Z-air. Works good except here in the PNW (Pacific North Wet) you have to empty the liquid and replace the cheap pellets every couple of months. I don't use it much anymore since I take the trailer south during the winter.
Old 09-21-2017, 12:45 PM   #7
I just looked up Davis 1458 Air-Dryr 1000 and it doesn't appear to have a way to collect the moisture but just warms the air so it has a harder time condensing. A simple space heater should work just as well. I use a combination of a space heater and Dri-Z-Air. Dri-Z-Air actually takes the moisture out of the air.
I would think that using a Davis 1458 Air-Dryr 1000 would make the inside of a trailer here in PNW like a steam bath.
Old 09-21-2017, 02:18 PM   #8
I couldn't tell if it was even on.
Old 09-21-2017, 02:46 PM   #9
Thanks Glenn.
It sounds like a good waste of a few bucks.
Old 09-21-2017, 03:50 PM   #10
Trailer: Burro 1983 13'
Wisconsin
Ditto on the Damp Rid. Have used it
for years and works well.
Not expensive either.
Burro Bill is offline   Reply With Quote
Old 09-21-2017, 03:56 PM   #11
Nik
Nik's Avatar
Trailer: BigFoot
Red face
Looks like Damprid wins this contest. Makes sense to me to pull the moisture out of the air. It's a very small space and will be well protected. I'll try a tub of this and check it in a month.
Thanks!
Old 09-21-2017, 04:07 PM   #12
This is Dri-Z-Air system, with cage for desiccant and pot under for liquid that results. Like others, I put mine in the sink or a pan in case of overflow ( which has never happened to me ).
Old 09-21-2017, 04:26 PM   #13
Dri-Z-Air at Amazon.com drizair
Cost $9.98 For the canister and almost one winters worth of crystals.
Crystal refills around $2.00 each package.
Large jug 60oz $13.00
Can't get much cheaper than that and it works quite well. I've used it for over 11 years.
Old 09-21-2017, 06:45 PM   #14
TomK's Avatar
In addition to the Damp Rid, I opened up all the cupboards, drawers, fridge, etc., and propped up the cushions on end to allow better air circulation.
Tom
5000 BTU Air Conditioner and 1000 Watt Generators FRANK MOLIS Problem Solving | Owners Helping Owners 1 08-15-2010 10:27 PM
Seminole Canyon and Davis Mts, Texas Horst K. Camping, Campout Reports 8 11-24-2009 07:10 PM
SOLD - 2005 Casita 17SD in Davis, CA Spencer Berry Classified Archives 1 02-14-2009 06:14 PM
More Davis Mtns (TX) State Park Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 1 09-28-2002 11:43 AM
