DIY Solar Panel - Fiberglass RV
Old 05-06-2018, 10:14 PM   #1
Larry C Hanson's Avatar
DIY Solar Panel
Hello,
Recently I was fortunate enough to notice a 100W flexible solar panel
on Ebay for about $60 shipped. I have a disabled pal living off grid in his
class C motor home who has been having trouble with his 80W panel due to
its weight. Consequently I decided to make him a wooden backing for the
panel with folding legs... Size is about 43" x 23". The finished weight is
about 15 lbs.
The legs are from a scrap pair of crutches.... with the hardware and
misc the total cost of the portable 100W panel was about $100....
BTW, the protective film is still on the face of the flexible panel.
Here are some photos of the project....
Old 05-07-2018, 03:04 AM   #2
Raz
Raz's Avatar
Very clever.
Old 05-07-2018, 09:21 AM   #3
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Very well done! Thanks for sharing. Was that flea-Bay purchase a one off, or is it from a vendor who has more? A 100 watt unit would be a little bit of overkill for my present needs with the Burro, but as I use it more I’d never have to worry about increased demand vs capacity. I can’t quite decide from the picture... can the legs be easily folded for transport, or is “some assembly required” each time it is moved?
Froggie
Green Frog is offline   Reply With Quote
Old 05-07-2018, 12:17 PM   #4
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Nice job. Kept the weight down!
Old 05-07-2018, 04:20 PM   #5
Trailer: In the Market
Virginia
Wow that’s terrific, what a great job and smart guy!!
mbbear is offline   Reply With Quote
Old 05-07-2018, 05:48 PM   #6
Radar1's Avatar
Good job and re-use of unused crutches.
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 05-08-2018, 10:34 AM   #7
100W Panel Source
Hello,
Thank you all for the kind comments....
I kept searching Ebay with these parameters:
elfeland 100 watt flexible
They were usually running about $115 to $150 with shipping.
One morning in April they popped up for $59 for some reason?
Anyway, I took that opportunity to buy a few of them.
Looks like they a running higher now..
Froggie, the assembly is simple. Pull out the legs from the back
and the put the ends of the panel bottom spacers bolt through
bracket and a wing nut.... See photo for that detail.
Good hunting... hope you find a bargain.
I am considering using two of the flexible panels to build a folding
portable one for myself for a 200 Watts out... hopefully keeping the
weight to about 25 lbs or so? Will post pix if project gets done...
Larry H
solar, solar panel
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Solar Panel Location Fred Modifications, Alterations and Updates 8 01-17-2007 10:26 PM
Solar Panel Sale Harvey Craft Modifications, Alterations and Updates 0 08-21-2006 06:38 PM
solar panel help Maggie Electrical | Charging, Systems, Solar and Generators 9 07-18-2006 04:38 PM
Canadian Solar Panel Barbara Gardin Electrical | Charging, Systems, Solar and Generators 5 04-01-2006 07:34 PM
