Does your Trillium weep? - Fiberglass RV
Old 10-18-2012, 05:57 AM   #1
Raz
Raz's Avatar
Vermont
Escape trailers come with "pontoons" to collect water should there be a leak and weep holes to evacuate that water. I notice my "new" Trillium also has pontoons but there are no weep holes. Are there weep holes on the original Trilliums? Raz
Old 10-18-2012, 07:46 AM   #2
cpaharley2008's Avatar
Smile
can't resist- maybe yours has a diaper!!!
Old 10-18-2012, 09:21 AM   #3
Raz
Raz's Avatar
Vermont
Mine's new, it's the older ones I'm asking about. Come to think of it doesn't your new one weep?
Old 10-18-2012, 10:36 AM   #4
David Tilston's Avatar
My 1973 1300 has weep holes, but the 4500 does not. Personally I think they are a good idea. I will be adding them to the 4500's when I get the proper drain fittings. I wonder why they stopped using them?
Old 10-18-2012, 04:18 PM   #5
Raz
Raz's Avatar
Vermont
Hi Dave. Mine was made by mistake. That is, they made lots of mistakes when they made it. Who knows, the other new ones may have them. Where are they located, and what size are holes? Also, fittings? Thanks, Raz
Old 10-18-2012, 05:29 PM   #6
They are a few inches ahead of and behind the wheel wells. They are about 1/2" in diameter. When I get home I will try to take pictures.
Old 10-18-2012, 05:53 PM   #7
I have a 75 Trilllium and yes there are drain holes, I added a couple more just to be safe. They are about 3/8 in diameter. Any larger and they may require a bug and rodent guard.
Ron
RRJR is offline   Reply With Quote
Old 10-18-2012, 08:45 PM   #8
Pictures
It looks like the curb side front of the wheel well, (under the door) doesn't have a drain.
Old 10-19-2012, 04:07 AM   #9
Raz
Raz's Avatar
Vermont
Thanks for taking the time. Looks like each side of the wheel well has one. The last picture seems to show a fitting? While you don't hear much about floor issues with Trilliums, moisture could collect in there and there is no way to know it's there, especially in the door area. So why they would leave that one out is mystery. Then again the holes could also let water in. Perhaps thats why your 4500 doesn't have them. Thanks again, Raz
Old 10-19-2012, 04:55 AM   #10
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
On my 1977 4500 water collected in all the low spots until I drilled outlet holes. After that no problems.
Old 10-19-2012, 06:02 AM   #11
Raz
Raz's Avatar
Vermont
Two questions. How much water came out when you drilled? Was the water due to condensation or did you find a leak? Raz
Old 10-20-2012, 08:26 AM   #12
I live in Las Vegas so it is really dry 95% of the time, however we do sometimes have some humidity in July and August. Some how, some way, I would go out to the rig and there would be water. Drove me crazy until I drilled holes.
Old 10-20-2012, 03:10 PM   #13
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
You lost me with the "pontoons" reference... since I'm pretty sure they're not for flotation, what exactly is their purpose????
Old 10-20-2012, 03:59 PM   #14
Raz
Raz's Avatar
Vermont
Run your hand down from the lower side of your Trillium underneath until you hit the frame and you will notice that you are following the lower half of a tube. That's the pontoon, a description coined by the folks who make the Escape. Apparently it's a trough intended to catch water that gets inside, diverting it away from the plywood floor. Raz
trillium
Source for weep hole covers Pamela S. Problem Solving | Owners Helping Owners 14 05-04-2010 07:10 PM
Weep hole leaks on Casita? sandan Problem Solving | Owners Helping Owners 7 06-24-2009 08:16 PM
newbie confused..which trillium to buy,,Outback (canada) or Trillium u lloyd cicetti General Chat 17 08-04-2008 07:46 PM
Fiber Stream Window Weep Hole Covers Frederick L. Simson Problem Solving | Owners Helping Owners 0 10-09-2007 10:27 PM
