Door molding color question - Fiberglass RV
Old 09-02-2017, 09:12 AM   #1
Trailer: 1992 Scamp 13'
Door molding color question on Scamp
My doorway currently has white around. My door has black around.
Is this standard?
I ask because I bought black and don't know if I should get white for that area.
lisantica is offline   Reply With Quote
Old 09-02-2017, 09:42 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I don't think it really matters. You're missing the weatherstrip which is most likely going to be black so matching will not matter any way.
Old 09-02-2017, 09:43 AM   #3
Good eye. I am installing the new weatherstripping purchased from Scamp today. My old stuff was deteriorating foam.
1992 Scamp 13' Standard, 2017 Casita 17' ID,
2008 Scamp 16' Deluxe Layout 4
Old 09-02-2017, 11:32 AM   #4
Kai in Seattle's Avatar
This is the new rib molding from Scamp, comes with attached gorilla glue peel n stick tape...
Anyone tried this? We "need" a new door seal but hesitate to try an automotive type. We want the door to still shut as well as it does. And meanwhile, Paul re-taped some of ours to make it stick and it is sticking...and it seems to keep water entirely out...
ideas?
Kai
Semper ubi sub ubi.
Old 09-02-2017, 11:36 AM   #5
My 1988 Scamp has white around the doorway on the body and black around the door. I don't think I ever paid attention so I had to go look! I've owned the trailer since 2002... you'd think I would have noticed it before
Old 09-02-2017, 12:38 PM   #6
The new ones have a black seal and a black door edge moulding.
Old 09-02-2017, 01:01 PM   #7
ideas?
Kai
I just installed the one from Scamp. It was an easy install once I knew which way the flat end went (away from the opening).
My door does shut a bit more snug, but not enough to where I can't close or open with just a little more pressure. My door handle isn't stock, so maybe that is why it is working out okay. Some have issues with having to pull their door tight, and/or adding a shim at the handle area.
Old 09-02-2017, 01:03 PM   #8
Yep, just like mine. I always like knowing what is original about my 1992 Scamp as the previous owner did do a few alterations.
Old 09-02-2017, 01:04 PM   #9
Some pics.
Old trim
No trim
New trim on
Old 09-02-2017, 01:08 PM   #10
And the rubber molding installed.
exterior door molding 13' Bigfoot Kenny Strong Problem Solving | Owners Helping Owners 5 04-18-2012 11:07 PM
entrance door molding, 1993 Bigfoot Kenny Strong Problem Solving | Owners Helping Owners 2 04-15-2012 12:53 PM
Need molding for beachcomber door LeeAnne Problem Solving | Owners Helping Owners 2 09-12-2007 07:11 AM
Door hinge/molding RicK M Classified Archives 0 10-07-2006 10:25 PM
