door window - Fiberglass RV
Old 08-13-2006, 04:05 PM   #1
The door window in my 1977 Scamp (13') was damaged when I bought the Scamp. I am thinking of replacing it w/a pc. of Lexan 1" longer & wider than the window opening. I will then put caulking on the door & screw the Lexan in place using 1"x1/8" alum flat stock & ss screws on the exterior of the door.
Anyone have a better idea?....thanks Don
Don Meyer is offline   Reply With Quote
Old 08-13-2006, 07:32 PM   #2
Brian B-P's Avatar
I saw a B1700 listed for sale with a slightly curved conversion van window installed in the door - it looked good.
My Boler has a flat Hehr window, but I assume that the Scamp 13' door surface is too curved for that.
Old 08-13-2006, 09:58 PM   #3
Pete Dumbleton's Avatar
You can buy replacement windows from Scamp, perhaps even one that can open a little and provide some ventilation (the one on my 91S13 does). There's a downloadable parts/prices list on the Scamp web site.
Old 08-15-2006, 02:25 PM   #4
Thanks for the replies.....The Scamp replacement door window will not fit my 1977 Scamp.
Because it is not a bolt in I am lookng for something cheaper. The van windows I've seen are all too big....help
Don Meyer
Old 08-15-2006, 02:47 PM   #5
Don Meyer
It would help to know the dimensions. The current Scamp door window is 15 x 15-1/2.
Old 08-15-2006, 02:51 PM   #6
Trailer: 1968 Venture (Molded Fiberglass 19 ft Class A Motorhome) and 82 TranStar B+
Send a message via AIM to Penny Taylor Send a message via Yahoo to Penny Taylor
The Entrance Door Window Frames that you can buy at the RV dealers are approx. 16" x 25", and come in different colors. About $7.00 each for the inside and outside. If that would fit, it would make a much nicer frame for your plexiglass.
Penny Taylor is offline   Reply With Quote
Old 08-17-2006, 11:48 AM   #7
I just went ahead & ordered a new Scamp window. It's going to require a lot of fiberglass work to install. I did this because my door was all rotted out inside So when I am replacing the interior I'll install the window.
Don Meyer
Source for Window on Door? Vic&Kathy Problem Solving | Owners Helping Owners 2 06-30-2010 12:19 PM
Fix for door window leaks DannyH Problem Solving | Owners Helping Owners 2 12-10-2009 07:26 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
window for boler door Janice M Classified Archives 0 07-15-2007 01:34 PM
door window assembly JNikirk Classified Archives 0 05-26-2007 09:46 AM
