Dripping sound after using water pump - Fiberglass RV
Old 08-16-2019, 09:52 AM   #1
Trailer: 2018 Casita Spirit Deiuxe
Massachusetts
I noticed that when I turn on the water pump, even though I'm not using any water, every few minutes it comes on for a few seconds. And when I turn it off, I hear a rapid dripping sound, somewhere on the right side, near the back of my Casita 16'. When I look under the camper I'm not seeing any dripping. Any thoughts on what is dripping and where?
Lisle is offline   Reply With Quote
Old 08-16-2019, 10:56 AM   #2
Originally Posted by Lisle View Post
I noticed that when I turn on the water pump, even though I'm not using any water, every few minutes it comes on for a few seconds. ..
That typically indicates a leak somewhere.
Old 08-17-2019, 11:03 AM   #3
The cycling pump could be from a tiny bit of dirt stuck inside one of the pump's check valves. The dripping? look into the compartments with the water tank, pump, water heater, etc. you may have a puddle of water in there that is not draining outside.
Old 08-17-2019, 01:45 PM   #4
Massachusetts
Found the leak!! It was coming from the fitting between the cold water line and the kitchen sink. A friend took it apart and put it back again and it's fixed!! Thanks for your suggestions.
Old 08-17-2019, 04:24 PM   #5
Kai in Seattle's Avatar
I'm so glad you found it and your friend fixed it!
Paul insisted I add, "If it drips after use,
you probably didn't shake it enough."
BEST
"K"
Semper ubi sub ubi.
Dripping sink ZachO Plumbing | Systems and Fixtures 15 04-19-2017 08:29 AM
Moisture Dripping from Below Rear Window fusedlight Problem Solving | Owners Helping Owners 8 08-17-2012 09:52 AM
water dripping from range hood JaneM. Problem Solving | Owners Helping Owners 11 06-07-2011 12:19 PM
Water Pump Not Working After Air Compressing nathanj04011 Plumbing | Systems and Fixtures 4 10-29-2007 01:22 PM
Water Pump Not Working After Air Compressing nathanj04011 General Chat 0 01-01-1970 12:00 AM
