Eeeeeeeeeee pressure wash caution - Fiberglass RV
Old 07-20-2015, 07:34 AM   #1
BatDude's Avatar
Trailer: Escape
A few weeks back after our last trip I ttok our Scamp to a self serve catr wash.
looks "New Brand" as we used to say in Belize.
While we beginning to re-pack and outfit for our next trip in 2 days my wife discovered a wet carpeted area under the fridge. Apparently the pressure spray from washing blew into the vents by the fridge area and leaked down inside the Scamp.
So now I will put a fan on it to dry it out so we do not get mildew or mold under there. Very small door space at floor level and since it is carpeted not an option to "mop up".
Just a note to other to be more careful than I was when washing our toys.
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 07-20-2015, 08:39 AM   #2
Name: Zac & Cathy
Trailer: Burro & 2006 21ft. BigFoot
Thanks for taking the time to let us know
Cathy
Avey is offline   Reply With Quote
Old 07-20-2015, 08:46 AM   #3
Bob Miller's Avatar
Any of the vent panels for the refrigerator and the water heater will let water in when sprayed with even the smallest hose, much less a high pressure car-wash hose.
On those parts of the rig, always back away and wash/rinse from well above the louvers, at last at a 45 degree down angle.
Ditto for roof vents, you can force water under the lid, lifting it off the seal and wa-la, you have that inside shower you always wanted.
Old 07-20-2015, 09:45 AM   #4
Trailer: 2010 Scamp 16
And avoid the "tire wash" setting. Stuff is very effective at removing wax job from camper shell. Unless you figure stripping the wax as part of your plan.
Maybe you can pick up some desiccant bead packs can help absorb moisture in close spaces. You may find them as bulk packs at sporting good stores, they are used in gun safes to prevent condensation.
Or run a dehumidifier in the camper. Dry air will such the moisture out. Eventually it will all dry. Thanks for sharing, probably will prevent some people having the same issue.
Old 07-20-2015, 11:09 AM   #5
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
A wet-dry shop vac can sometimes be used to suck out some water from carpet, if it's badly soaked. Hopefully you didn't get it that wet, though.
Old 07-20-2015, 12:48 PM   #6
On this RV fridge manual, page ten, section 2-A, it says in bold type:
NOTE: AVOID SPRAYING WATER THROUGH THE
REFRIGERATOR VENTS WHEN WASHING THE RV
Yes, real men DO read the instructions!
Old 07-20-2015, 01:21 PM   #7
Bob Miller's Avatar
Ha... Instructions are intended for use AFTER you can't make it work and/or cause damage.
Old 07-20-2015, 01:24 PM   #8
Exactly.. I didn't read the manual until after I read batdude's post!
Old 07-20-2015, 03:24 PM   #9
Carl Pa's Avatar
I got water under fridge on the first melt of snow and ice off camper. Ice i guess from condensation got up under there and seeped into vents. I think while it is stored in winter, I will, if safe, tape on some plastic. Also put some kind of fine screen in spring on all vents b/c of bees, got some of them in the insulation of fridge, I just got out of there last week. Always something. Carl PS will get a roof broom this year to keep the higher snow off and somewhat clear of snow.
Carl Pa is offline   Reply With Quote
Scam? Proceed with caution... Frankly I wouldn't touch this with a 10 ft pole! Robin G Referrals: Molded Fiberglass Trailers 6 08-24-2010 09:39 PM
Caution - Shady underworld Boler flippers at play Darren C General Chat 47 07-09-2007 08:06 AM
CAUTION - New Virus Bigfoot Mike Jokes, Stories & Tall Tales 11 01-10-2007 07:32 AM
Caution - Shady underworld Boler flippers at play Classified Archives 0 01-01-1970 12:00 AM
