Eggshell clean and shine time - Fiberglass RV
Old 03-25-2014, 01:29 PM   #1
OK, time to clean up the egg shell of our recent purchase--'99 Scamp 16 footer.
It was sitting in a driveway under an oak tree the past couple years at the time we purchased it. Steve scrubbed it quite a bit, mostly on top, and moved it to covered outdoor storage nearby to continue cleaning and prep. I was thinking Spic N Span solution or Simple green, car wash soap etc. might work for general cleanup on the white gelcoat. We are hearing that Bar Keepers Friend works good ---in what form-- powder, cream, spray, foam? Do you use that over the whole thing or just blemished areas.
So then once it's really clean then you apply something for shine. ZEP is mentioned quite a bit in the care threads but we welcome suggestions.
This might be the time to look for replacements for original rusted door hold catches, etc before the shine goes on. I'm wondering if those pieces are specific to Scamp or if most RV stores would have some universal pieces.
Somebody tell us about these rivet attachments for curtain hardware. Do those just go thru the rathair mat only? I guess we are not so rivet-savvy. Just one of those to repair--I hope. Come on Spring weather!
Steve n Donna M. is offline   Reply With Quote
Old 03-25-2014, 03:25 PM   #2
Donna on a 99 I would defenetly go with the zep.would not waste time or money on any other product
Mikmay is offline   Reply With Quote
Old 03-25-2014, 04:07 PM   #3
I used the barkeepers friend liquid to clean our '84 Uhaul and it worked good. Scrubbed it with a small sponge or rag. Washed that off with lots of water and a car wash sponge. I'll stay out of the wax discussion as there are several opinions. From pictures I've seen looks like the door hold is a common part. Looks like what we used in the trucking industry.
mary and bob is online now   Reply With Quote
Old 03-25-2014, 06:36 PM   #4
Wallo's Avatar
Utah
There is alot to read but the thread
Check this out NOT Poliglow...Time will tell..
is extremely informative. I personally used Zep wet look floor polish on my Scamp this spring and it transforms it from an ugly duckling to a swan. Before applying Zep, I used barkeepers friend to clean, followed by a rinse of TSP.
Alice
Wallo is offline   Reply With Quote
Old 04-07-2014, 12:30 PM   #5
The top massage continues
Thanks. We did look at the post about the floor finish stuff there and from several others.
But Steve's a car guy and he can't quite convince himself to go with the floor stuff. So far he's using a Macguire's color restorer product so he might just stick with that system. He's going to know every inch of the thing, rubbing a few years of grit off the gelcoat. Still just working on the top so far. We have a pretty scuzzy belly band to redo also I think. Then wax...or something shiny
I've about decided to try using a spring tension curtain rod for the back window instead of fixing the bad curtain rod bracket/rivet---at least for now.
All that talk about Missouri Ozarks on the Rally threads has me thinking about a shakedown trip but probably not till June for us.
Old 04-07-2014, 02:43 PM   #6
I used KIM household cleaner, it has a very mild abrasive that won't harm the gel coat, but will clean the chauky stuff off. Rinse it very well and then applied 5 coats ZEP, WET LOOK FLOOR FINISH. Did a fantastic job. If you use a wax you may run into problems later if wanting to touch up some paint spots.
RRJR is offline   Reply With Quote
Old 04-07-2014, 05:11 PM   #7
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Donna, I'm with Steve on this one...only if it lasts. I used to have to polish & wax our Scamp every 3 or 4 months due to the dullness coming back. I finally gave into the floor finish method and was very pleased with the results. It shined better than ever, adhered well, and sloughed off dirt & road grime better than any product I've ever used. The original coating was still working well without yellowing after 3 years.....I have since sold the Scamp
Dave & Paula
Old 04-07-2014, 06:53 PM   #8
3M Marine Restore and Wax will take off all the gunk and leave it nice and shiny.
Old 04-07-2014, 08:27 PM   #9
Gilda's Avatar
Trailer: 2011 Scamp 13'
Chances are a tension curtain rod will not hold up while under tow. It could be a good temporary solution while you are in camp until you rivet in the new rod holder. 'Thought I'd just take a minute to show off my curtain and black out shade solution (see photos).
I kept the original Scamp curtains because they are light in color, letting in sunlight during the day. I simply change the decor by sewing side panels in a novelty fabric. (I find a pattern all around the FGRV interior is too overwhelming in the small space.) By making panels I use little fabric thereby saving on cost. These photos show my fall foliage theme. I made a hand-rolled shade out of Ron-Loc black out fabric (available at most fabric stores). It has Velcro on the bottom to "stick" to the rat fur. I use the regular curtain rod holder for the curtain as it keeps the rod firmly in place while under tow. The black-out shade is on a narrow cafe curtain rod which simply rests on top of the curtain rod holders. Note: I am thinking of tying the regular rods to the rod holders because they do sometimes fall off in transit. I found that the original Scamp curtain rods were too narrow for the holders so I purchased thicker rods that fit more snugly in the rod holders.
The Gleeful Glamper
Gilda (Jill-da)
Old 04-07-2014, 09:39 PM   #10
The rivets do go all the way through the fiberglass shell of the trailer. Go outside and pop the cap off the rivet and drill out the old rivet and pop in an new one.
Old 04-07-2014, 09:45 PM   #11
Trailer: Hunter I
Scrub the whole trailer with bar keepers friend. Then wash it with dish soap to get it preped and clean, let it dry then apply 3 to 5 coats of Zep wet look floor polish, trust these folks it works wonders.
BuddyLee is offline   Reply With Quote
Old 04-07-2014, 09:48 PM   #12
Roy in TO's Avatar
Or if you are unsure about placing new rivets, some have gone the route of using Stainless machine nuts and bolts with lock washers.
Old 04-08-2014, 07:53 AM   #13
The Op's trailer isn't all that old only a 99 so it should clean up nicely using a more traditional approach to shining up fiberglass as they have suggested their partner wishes to do. I know my 92 did .
Old 04-08-2014, 09:31 AM   #14
Thanks, Gilda. I did find lots of your photos in the gallery already---liked the memory foam casings idea and window treatment ideas too. I hadn't thought about the tension rod wiggling loose in transit. We'd have to go with the 60' size because the space is just over 48". I think it could be installed with quite a bit of tension on it since it can cover alot bigger space than needed.
Rivets maybe aren't as big a deal as they seem at the start. We'll see. We are missing several caps outside and found spare caps in the trailer but think we may need the washer pieces or something. Donna
To shine up my Burro... And, fix some holes. Creek Conley Problem Solving | Owners Helping Owners 10 04-15-2012 09:41 PM
protecting your Eggshell cpaharley2008 Problem Solving | Owners Helping Owners 0 07-20-2011 06:08 PM
How clean is clean? Liz&Kev Care and Feeding of Molded Fiberglass Trailers 13 06-12-2009 06:41 AM
Want the shine Gerry Problem Solving | Owners Helping Owners 20 10-13-2006 06:30 PM
My shine is back Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 06-21-2003 07:54 AM
