01-18-2013, 10:38 AM
Trailer: 1985 UHaul
Electric at campgrounds
OK -- here's a question exposing my ignorance: when you're hooking up electric at the post, what kinds of outlets are usually available? Is it possible to plug in a 120-v extension cord (heavy-duty construction quality)?
01-18-2013, 11:04 AM
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester
Louise:
At the campgrounds we have been to in BC, Washington and Oregon, usually there is a 30 Amp connection, often also a 15 Amp connection. Some campgrounds also have 50 Amp connections. Our trailer (an Escape 13) came with a 30 Amp power cord, and we have never had problems getting power with it. If you want to connect at home you may need an adapter to allow plugging into a regular 15 Amp outlet.
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
01-18-2013, 11:41 AM
Trailer: Scamp 16'
Utah
Same as Brian-I have found both 15amp and 30 amp at the campgrounds I have stayed in-that had power.
Dennis
01-18-2013, 11:51 AM
Around Michigan I have seen pretty much what Brian reports. A normal household 15A receptacle and either a 30A or 50A plug. On rare occasions there can be both a 30A and 50A connection in addition to the 15A.
My Casita comes with a 30A connection so I carry a 50A (male) to 30A (female) adapter and also a 30A (female) to 15A (male).
If the trailer comes with a 15A plug, there are adapters for that, too.
If someone's handy and pays attention to wiring conventions I know some frugal campers can wire their own adapter. I don't bother.
I offer this extra tidbit because it sometimes comes up but, assuming the trailer is protected properly with circuit breakers appropriate for it's wiring, there is no issue with plugging a 30A plug into a 50A receptacle (assuming an adapter). The 50A isn't forcing 50A into the 30A plug, it's just a descriptor of how much the receptacle can supply before tripping itself. Your (that's the global you) trailer should only take 30 of those 50A before it's own circuit breaker(s) trips.
01-18-2013, 12:09 PM
Louise:
The 30 amp connection looks like this (pick 30 amp in top left):
RV Electric
Note that it is a 110 volt service.
To plug in your trailer at home you may need this:
Plug Adapter for RV Power on Sale - PPL Motor Homes
You will need the 30 amp female to 15 amp male.
Brian & Maria
01-18-2013, 12:15 PM
Cost Adaptor
I was planning to make a 50 AMP to 30 amp adaptor but after going to my electrical wholesaler and pricing the parts,I could not make one as cheap as buying one . I can purchase a manufactured adaptor for under $20.00 and the parts to make one would cost me (Best contractors price ) over $30.00. Plus the manufactured adaptor has molded ends which help keep rain out of the connections
01-18-2013, 12:35 PM
Trailer: 1985 UHaul
Ah-ha! I needed the photos!
Just to be clear -- I don't have a trailer yet. I do have camping gear, and I can manage ok without electricity -- but if I'm going to be out for a few weeks, I would like to be able to plug in a standard extension cord and run my computer for a few hours.
I'm hoping this will be the Year of the Egg -- fingers crossed!
01-18-2013, 12:36 PM
Trailer: 2007 Casita
Louise, your not ingnorant! Just not campground/trailer savy! You will be, nice to see a newbie "planning", educating themselfs!
Most Campgrounds/rvparks I have been in provide 50/30/15 amp all on the same post. CO, CA, NV, AZ, UT, ID, WY, even many in MT. Depending on what type of trailer you purchase will depend on what type of service you will have. Most newer trailers will automatically come with 30 amp wiring. Older ones will either be, 15 or 30 amp.
Truly no reason to plug into 50 amp, though on rare occasion you will get a camp site that only offers only 50 amp. Then you will need to have a adapter in that case. But (BIG BUT) your trailer will still only have 15/30 amp capability! And trying to use 50 amps of power through 30 amp wire is not and I repeat NOT a smart thing to do.....
This is very rare, unless your in a new/newer campground/rvpark.... 50 amp service is made for those big travel trailers/5thwheel/Motor Coaches. And many of those are not even 50 amp! Not our lil travel trailers.
Of course there are people who choose to re-wire their trailer to meet their needs, but you will know what amp's your trailer is when you see the plug.
Good luck in your search, you will find it fun. Hope you find what your looking for soon..........................
01-18-2013, 12:43 PM
Originally Posted by Robin G
... But (BIG BUT) ...
What did you call her?
Oh, wait a minute....only one "T".
Nevermind...
01-18-2013, 12:49 PM
Louise:
There are many more camping spots without power. If the only power you need is for a computer, you can get a small inverter which will allow you to charge your computer when you drive. Something like this: PowerLine 200 Watt Inverter: Home Audio & Theater : Walmart.com
When we were tenting we used an inverter with an extension cord to inflate our airbed.
If you have a camping spot with a power pole you may find that you are charged extra for having a serviced site, but an ordinary extension cord will work just fine.
Lots of options.
Brian & Maria
01-18-2013, 12:53 PM
Nevermind...
http://www.rvtechlibrary.com/electri...eloadchart.htm
Louise, here's a amp chart as well as a decent explanation of amps. The charts help. Unfortuanately they do vary do to the person who put the chart together most likely uses the amperage from his or her's rv appliances. But most get close. If I remember correctly there was a topic here are the A/C on a new Casita. If I remember right, the amp on start for it is higher then amps down after start up. But I still think higher than this amp chart. But again even this helps.
The best way to know exactly what amps your, A/C, coffee pot, curling iron etc uses is to read the manual that comes with it. Even my curling irons state what amps they use (I personally don't ever keep that info, it goes in the trash along with the box it came in) But you can find that info......... Again, Good luck!
01-18-2013, 04:09 PM
Trailer: Class A Motorhome
In the USofA, (at least to be UL Listed) all appliances must have the voltage and power draw indicated on the appliance. These values are usually molded into the base or near a mfg's tag. Divide watts by 120 for amps. ex. 500 watt heater = 4.16 amps, a 150 watt curling iron (we're camping???) = 1.25 amps etc.
01-18-2013, 05:28 PM
Bob, Robin is a certified member of the Glamping fraternity, so yes a curling iron, is a camping necessity
01-18-2013, 06:49 PM
Trailer: 1985 UHaul
So much to learn -- you guys are great teachers!
01-18-2013, 06:54 PM
LOL, your point is ? Bob, after camping almost 40 plus years with my curling iron, makeup (my Mom packed for me before that) in tow I finally fit in.............. Love that glamping has become the hit thing! Kinda like that country song, I was country before country was cool...... Well I have been glamping for years and years. I even own a butane curling iron for dry camping...... Wish I could find a butane flat iron, I would be a happy glamper!
01-18-2013, 09:02 PM
Trailer: Chalet
You Go Girl ! oh and keep looking I have seen a butane flat iron somewhere ,but unlike some people( Donna D is wonderful at it ) I can not remember where.
Just a thought have you checked dive sights? Our DD use to scuba dive and she got her butane curling iron from a dive shop vender at a trade show one year. Of course that was at least 10 years ago,but who knows
01-18-2013, 09:38 PM
Trailer: U-Haul 1985
Louise, I carry an adapter that will let me plug a 15amp cord into a 30 amp receptacle. I've gone to a few parks that had 30's and 15's BUT the 15 amp plug was not working. The adapter allowed me to plug my 15amp cord into the 30amp receptacle. They cost a few bucks but can save you a big headache!
01-19-2013, 01:55 AM
[QUOTE=Lynn Musgrave;357041][QUOTE=
[/QUOTE]
I understand Lynn! Many times I post a question about a old topic, pic etc, knowing Donna D will be the first to answer it. She has a wonderful memory!
No and CO isn't the diving capitol of the world, but I do know many who do dive. I will put them on the hunt! Thanks for the tip....
Now that will happen more often than just about any other scenario mentioned. If your trailer is a 15 amp, like Pam you should carry a adapter.
01-19-2013, 09:44 AM
Trailer: 1985 UHaul
Ah-ha! They do make an adapter for that! Yay! Thanks, Pam.
01-19-2013, 10:00 AM
Conair TC701 Butane Flat Iron
Glamp on Girl!
